Suspension advice needed
(In Topic #142196)
I have bought a pair of front shock top mounts and a set of coil overs off ebay. Are there any other parts that need replacing while doing this and if so can you guys point me in the right direction.
Thanks in advance Robin
Apart from that unless you snap a bolt you should have all you need.
Robin
The fronts are 2 bolts, one is standard nut/bolt, others are camber bolts, depending on which suspension you bought, you may have some in the box.
You may also find once you have the shocks on, the ride is harsher, worth cheching cndition of rear beam mounting bushes and wishbone bushes, if these are shot then you may find a bit of crashing over bumps….
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
