Please help
(In Topic #142101)
![Caboverde in the usergroup ‘Newbie’ Caboverde in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Please help
Recently bought clipper cabrio, now horn sounds when I turn or indicate, this only started today after I had sounded horn
John
Clipper Cabrio 1990
Clipper Cabrio 1990
remove steering wheel horn pad.
Undo the big nut and pull steering wheel off.
You will see a little copper tab, this connects to the horn ring on the steering wheel, what can happen is that the tab can get pushed down and shorts out on the lower screw that holds the indicator stalk assembly in place.
Bend the tab up and stick some insulation over the screw head.
This is waht happened to mine..
Hope that helps.
Chortle
John
Clipper Cabrio 1990
Clipper Cabrio 1990
John
Clipper Cabrio 1990
Clipper Cabrio 1990
![Avatar](https://i1096.photobucket.com/albums/g329/baggie1005/SDC10038-1-1.jpg)
![baggie in the usergroup ‘Old timer’ baggie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
Just need the dry weather now
John
Clipper Cabrio 1990
Clipper Cabrio 1990
John
Clipper Cabrio 1990
Clipper Cabrio 1990
