MarsRed Cab 16v Conversion * NOW STARTED*
![Avatar](https://i1111.photobucket.com/albums/h478/denisotto/mk1kuf-1.jpg)
![denisotto in the usergroup ‘Local’ denisotto in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
and ive got connection ready for air inlet temp sensor
believe it or not the induction kit i have accommodates it.
ANYWAY GOT TO WORK TODAY ENGINES IN FIRST OF ALL
ABOUT TIME
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0532.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0533.jpg)
HERE IT IS WITH THE INLET MANIFOLD ON
HAD TO FIT IT BEFORE I ASSESSED WHERE TO PUT THE ECU
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0534.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0535.jpg)
NEXT TO PUT THIS SOMEWHERE
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0536.jpg)
HERE SEEMS PRETTY GOOD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0537.jpg)
HAS SOME 1 INCH OR SO OF MANOEUVRE BUT IM PREPARED TO MOVE IT INCASE THE ENGINE
ROCKS TO MUCH ONCE ITS IN????????????
WE SHALL SEE
THIS IS HOW I LEFT IT TODAY
MOST ANCILLARIES CONNECTED LIKE THE NEW COIL AND SUCH
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0538.jpg)
STILL NEED TO
FIT MY EXHAUST SYSTEM ON
FIT FUEL PUMP AND RESERVOIR
WIRE UP FUEL PUMPS
FIT NEW DISCS AND PADS
PAINT CALIPERS
FIT INDUCTION KIT
HERES SOME OF MY NEW STUFF
PRESSED PLATES
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0540.jpg)
DISCS AND PADS
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0541.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0543.jpg)
INDUCTION KIT
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0542.jpg)
FUEL DELIVERY SYSTEM
PUMP ACCUMULATOR AND RESERVOIR
![](https://vwgolfmk1.org.uk/uploads/pbextract/1186334/IMAG0544.jpg)
SO CLOSE TO BEING FINISHED NOW
preferably i would drill a hole in the bulkhead and run it up in the scuttle. use the size of hole for the main looms as a guide and get yourself a mk1/2 grommet to fit. cut this lengthways and tape it over the ecu loom.
I'll just get stuck in and do my own wiring.
Is it just run a positive from the lift pump and main pump onto plug n on the fusebox with an online fuse
Of how many amps
And an earth
Or is there more to it
Seems a bit too straight forward if you ask me?
![Avatar](https://farm6.staticflickr.com/5118/7081033079_b9d6aa250e_q.jpg)
![tomsdubs in the usergroup ‘Local’ tomsdubs in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
earth for pump just run to the earth claw above the fusebox.
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Ffuseboxce1.gif)
Cheers for that
I like the diagram as well
Makes a world of difference to understand
I know the abf engine has 150bhp standard
But wanted to know if anyone knew or had good comparison to estimate the power of the abf once
De catted
Exhaust manifold and system fitted
And induction kit applied
what would be the bhp of that?
Has anyone had this with similar mods and a dyno?
Give me a shout if you might know
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/glr.jpg)
![richievr in the usergroup ‘Old timer’ richievr in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Ref your question on bhp, a friend of mine had a mk2 16v we put an abf lump in it, we used the std mk2 kjet injection, a decat pipe and 4 branch manifold. It was rolling roaded at 172bhp and was a rocket! :-)
I would hope you would have similar results . . . .
just need to confirm a few things now and thats it.
lets allow the pics to do the talking……………………
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0552.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0553.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0556.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0554.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0594.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0604.jpg)
I REALLY LIKE THIS PIC..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0589.jpg)
TO SUMMARISE
IVE FITTED EVERYTHING ON NOW AND IVE ONLY GOT TO WIRE UP THE FUEL PUMP AND IN TANK PUMP
AS WELL AS CONFIRM THE WIRING FOR MY STARTER AND ALTERNATOR IS CORRECT
HERES WERE I NEED A BIT OF HELP….
1
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0593.jpg)
THE WIRES IN MY HAND ARE THE ONLY 2 WHICH COME FROM THE ALTERNATOR
SO THERE IS ONLY 1 THIN BLUE WIRE AND A LARGER WIRE CONNECTING THE STARTER AND ALTERNATOR
IS THAT CORRECT????
I QUERY IT BECAUSE I WAS UNSURE HOW THE POWER FROM THE ALTERNATOR WILL CHARGE THE SYSTEM
2
1 FOR RUBJONNY…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0600.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0598.jpg)
IS THIS WIRE IN MY HAND THE 1 FOR THE FUEL PUMP. THE E13 PIN?
IF SO. IS THE PIN PLUGGING INTO SLOT E13 AND THE FREE END IS 1 OF THE 2 LIVES FOR THE FUEL PUMP
3
FUEL PIPING AND SUCH
![](https://vwgolfmk1.org.uk/uploads/pbextract/1192770/IMAG0603.jpg)
IVE CONNECTED THE FUEL RESERVOIR AND PUMP IS ALSO FITTED AND ALL I NEED TO DO NOW IS FIT A PIPE FROM THE PUMP TO INJECTION RAIL AND A RETURN BACK TO THE RESERVOIR.
THE ISSUE IS WHERE CAN I GET A CONNECTOR FOR THE TYPE OF CONNECTION IN THE PIC???
SO CLOSE NOW…………..
SO CLOSE…..
![Lee_dub in the usergroup ‘Old timer’ Lee_dub in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Btw, car looks ace mate :-)
Lee_dub said
Your Altenator connects to the battery via the starter… Ao you should have a thick cable from alt to starter as you have and then another thick red cable from the same point on the starter to the battery positive
Thanks a lot mate.
Really appreciate that
Just need to finish off the engine and then get the interior retrimmed in leather with matching headliner.
the blue wire is the charge light on dash, this plugs into blue wire on the engine or lighting loom. basically on alt is d+ wire which is a 2 pin plug, blue wire runs from this to near the starter/battery depending if you use mk1/2 or mk3 alternator wire. mk1/2 goes to spade near battery +, mk3 goes to a small clippy waterproof plug.
2. yes pop that pin into E/14, its the only hole it will fit into on plug E so you cant go wrong. E is the smallish black plug for the rear wiring loom, easy peasy. then 1 wire to a spade for the abf fuel injector and lamda power, other wire run to your fuel pump(s)
that red wire on the relay needs to go to a permanent live spade on the back of the fusebox. if you look there are 2 groups of spades, the live side is where the 2 massive chunky red wires go
3. if you can find old mk1/2 k-jet metering head feed/return lines, you can cut the plastic/rubber pipe off the fitting. then you end up with a barbed end with thread that goes right into the old k-jet feed/return lines, and you push your abf hoses right over the barbed end and secure with proper fuel pipe clip
http://www.demon-tweeks.co.uk/motorsport/fuel-hose-fittings/fse-1-4-bsp-push-on-pipe-union
Cheers for the advice. I know exactly what I need to do with the fuel pumps now with the exception of the order of the in tank pump connections.
I've heard you can use a 3 pin plug from a mk2 headlamp fitting for the polo g40 lift pump connection.
See pic in posts
Is this right and if it is can this be purchased from main dealer still?
yeah the mk2 golf headlight leveller plugs will work, or pre-90 mk2 golf lift pump plug. its all over older dubs really. no need to buy new as you can easily take the pins out and put fresh ones in they're std latched female spades 2.8mm, Ref: 3-2921-2/10:
http://polevolt.co.uk/acatalog/2.8mm_Terminals.html
need a good crimp tool though as they're small!
311 906 231 B - plug, 3 pin - 1.80+VAT
867 972 525 - protective cap - 3.2+VAT
I think I may very well have it started on Saturday. Fingers crossed I can establish the order of the pins on the sender/intank pump.
Can I confirm does the vacuum from the servo connect to the connection on the rear of the inlet manifold.
Does it need any 1 way valve? I can remember if it had 1 with the carb engine connections.
Cant believe how close it is to being finished now. Thanks for all the help from everyone so far.
Couldn't have done it without you
the big connection on rear of inlet is for the servo, and ya you should have a 1 way valve on that pipe. it holds vacuum in the servo after the car is switched off, any mk1, 2 or 3 valve will do you fine. just make sure that any rubber tubing you have holds its shape under vacuum, oh and that you put it on the right way round
The end with the electrical connections or the other.
