desperate help guys!regarding 9j all round bbs splits
(In Topic #141492)
![gti_lee in the usergroup ‘Regular’ gti_lee in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
lee
you could get new dishes, to take them down to 7 front 8 rear, or sell them me!! lol
paul_c said
It doesn't matter how desparate you are, you can't fit something 9" wide into a gap too small for them.
i know mate,what i mean is there any possibility to get them to fit atall?ive seen close to this fitted in golf+ before,ie 8.5?so im not far off so wondered if anyone on here has done this and how
Whats your wheels off set? you might have a odd ball set anyway
![golf1980 in the usergroup ‘Paid Member’ golf1980 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![golf1980 in the usergroup ‘Old timer’ golf1980 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
do the barrels not hit the suspension being that wide and with that offset?
i'd be supprised if you could get the mounting face near the hub! i'd double check et mate.
have you thought about berg cup style arches?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1183967/190820102002-small-1.jpg)
had to have some work done on the arches and gave it a bit of camber and they sit flush now
![](https://vwgolfmk1.org.uk/uploads/pbextract/1183972/DSC06900.jpg)
http://www.frankiespaintshop.co.uk/
he is a top bloke and loves his vws.
he rolled the arch lip at the top only (this helps keep the wings rigidity) and flared them out slightly and on the rear he cut the lip back and re welded it in some way that keeps it all smooth so if it does scrub, the tires dont get damaged. he did a really good job of them i think.
front track is wider on a mk1 so i gave them a slight camber to get them under properly.
i also run slightly stretched tires to keep the tread under the arch.
that is about it
![](https://vwgolfmk1.org.uk/uploads/pbextract/1183985/DSC06886.jpg)
![hibbs in the usergroup ‘Old timer’ hibbs in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
will take one later,the fronts are only 7s thoughgti_lee said
same size tyres mate :? so shouldnt be to much a problem really then,have you got a picture of yours on?
