mk1 ABF project
(In Topic #140890)
mk1 ABF project
I was just wondering if the brakes will also be usable on my mk1, any other bit that can be used?
thanks for the help so far =)
Ive Drove Many Cars, But NONE Like A MK1
On topic - The original mk1 gti brakes are fail for this type of conversion- I would really suggest Uprating the Servo, Master Cylinder and Brake Disc's - Callipers Carriers Pads.
You will need 15" wheels to run the 280mm's and trust me you will need the 15" wheels
scrabble said
oh right ok, and yeah bike carbs i the way i was heading :-) was you running on much else or just the carbs? did you have it rolling roaded?
Slightly off topic in this section. abf - 150hp and carbs around 20-30hp more. To benefit the most, you want a uprated exhaust system. 020 box is fine ( I used a short ratio 020 from 1.6 GTi ) You will need the Bike Fuel pump, with in built regulator.
Perhaps a catch tank aswell. Rolling Roaded was tested at 178bhp - You dont need any more as its very uncontrollable to drive with all the wheelspin.
