hot start problem
(In Topic #138698)
![dek in the usergroup ‘Old timer’ dek in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
hot start problem
it will start again im getting stressed now need help please with auto elecy
i'am a mk1 golf nutter RHODEISAN RIDGEBACK mk1 cabbys rule and you drool
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![jellybelly in the usergroup ‘Paid Member’ jellybelly in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jellybelly in the usergroup ‘Regional Hosts’ jellybelly in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![jellybelly in the usergroup ‘Old timer’ jellybelly in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
cheers jb p.m my your address mate and post code will saturday be ok ?jellybelly said
dek bring it round this weekend and i'll have a session on it
i'm sure it wont be nothing to difficult![]()
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
Could be:
Leaking injectors - whip them out and put in jars to test.
WUR giving an incorrect control pressure for hot start, hence a crap mixture - measure it !!
Accumulator no holding system pressure, it should hold of 25mins before pressure decay starts - measure it !!
Check valve on the end of the main pump partially blocked, which means fuel will leak back - take is out and clean it.
Fuel pump really overheating, which can lead to fuse box corrosion - look for heat damage.
thankslhasadreams said
Can you smell fuel when trying to restart ?
Could be:
when go to resatart there is no power going to the starter until i run a wire from the battery this wire and then it will start .i have always smelt petrol ever since had car ?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I had this problem and it was the starter motor.
The heat from the exhaust manifold tends todo em in.
We had cured it for a while as there is a wire with a connector that goes funny.
I think from memory Dek has had new starter, new ingnition switch etc. It's baffled us for a good while.
It will start by hot wiring it straight from the battery so it kind of points to ignition side, probably heat related as when hot a connection expands so breaks the circuit, when cold the connection is remade.
Hope it gets sorted Dek.
chortle said
Ade it's a carb model.
hoping to go upto JB's on saturday
![AmaZak in the usergroup ‘Regular’ AmaZak in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Did you ever get this fixed, mine has the same problem.
Golf MK1 Sportline, Golf MK2 Driver, Golf MK5 Gti, Jetta MK5 TFSi
Just started to investigate my problem and looking around to see if anyone else may have possible solutions that worked.
hot start problem
hot start problem
![Avatar](https://i1145.photobucket.com/albums/o517/kimblesblue/401315_10150557134864847_681409846_8757639_1643757643_n-1.jpg)
![Kimblesblue in the usergroup ‘Local’ Kimblesblue in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
My dad used to say I squandered money, so I made an invested in my Rivage he's still not happy - but I love my money pit!!
AmaZak yours a GTI or carb model.
chortle said
There are differences between GTI and Carboureted models though.
Mine is a Gti, however my friend has convinced me to ditch the K-Jet injection completely and fit a golf mk3 setup with standalone management so I have bought mk3 engine and he is going to fit it for me, might get a few engine mods too :twisted:
