top mount, rubbers, are they easy to do?
(In Topic #122281)
I am due to take the car for MOT soon, I had an advisory last time excessive play for and aft of mc pherson strutt???
Apparently I need to change the top mounts and rubbers.
I suppose I should do the rears and bump stops at the same time.
So help please if you got a how to or can explain the process, then much appreciated.
Cheers all
![Dibdub1 in the usergroup ‘Local’ Dibdub1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
IMO the easiest way to do your two front top mounts/rubbers (all one unit?) is firstly undo the bolt that secures the suspension piston to the top mount till it's just about off.
Then, simply to jack the car up high enough to take the wheel off, undo the two top mount bolts and drop the suspension arm down as far as possible.
Once you've done this, undo the bolt completely, lift off the old top mounts then put the new one in place, tighten up the bolt a little bit and then re-align the top mount, put the two top mount bolts in place and tighten as much as possible by hand, then simply tighten up to a nice "nip" with the ratchet and then tighten up the top mount/suspension piston bolt as tight as possible.
Rears, jack car up, take wheel off, undo bottom bolt and remove from axle, then undo top bolt and drop the suspension strut out, remove and replace top mount/rubber, re-assemble!
Voila!
Done!
Hope this helps =]
Cheers, Josh.
![GTI_sam in the usergroup ‘Local’ GTI_sam in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i48.photobucket.com/albums/f227/GTI_sam/DSC01122.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20200305_113915.jpg)
![Diesel-dubber in the usergroup ‘Local hero’ Diesel-dubber in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Cero said
That's what the allen key hole is for :redfaced:
No blushes here. You have to learn some how!
Many thanks Diesel Dubber. That's what I needed.
![jayjay31 in the usergroup ‘Local’ jayjay31 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
1.8T CABBY
1.8T CABBY
![Avatar](https://i2.photobucket.com/albums/y12/danieljephcott/Untitled.jpg)
![danj in the usergroup ‘Paid Member’ danj in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![danj in the usergroup ‘Local’ danj in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Just a quick one can you do it without undoing the to bolts at the bottom with the camber adjustment etc as ive not long had my camber done and last thing i want to do is chuck it out again.
could i just under the top mount bolt, jack car up, take wheel off, undo 2 strut bolts at top then pull strut down, undo the top mount bolt completly, take off top mount and replace and do it all back up.
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.socfx.com%2Fwp-content%2Fuploads%2Fsuningolfcopy20.gif)
If top mounts are changed you're supposed to get the tracking adjusted afterwards anyway, meaning a trip to a tyre fitters or similar, so they would be able to check the camber at the same time anyway. If you mark the bolts and strut carefully before removal the camber won't be a mile out on refitting.
I paid a local garage to sort these out about 12 months ago and what a mess they made !
1) they used cheap mounts but I suppose they wouldn't have know , these were knackered After only 900 miles
2) One bump stop was the wrong way round and the other only had half the top on it the bottom was worn away
3) no spacers on the mount which had caused inside the mount to thread from the bolt
All back on now and no banging over pot holes
These guides helped especially the link with photos but you have to take the spring out and use spring clamps ( £10 ) ebay
Its so much easier to work with on the floor and with the clamps on
Advice make sure you get correct mounts and the spacers and invest in clamps it took me 2 hours in total and saved £100 garage fee
If any one needs to use my spring clamps there welcome I'm in Kirkham off the motorway m55 near preston and blackpool
Jay
Jay
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9image.jpg)
![Massbad69 in the usergroup ‘Local hero’ Massbad69 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If I can do it anyone can.
