using brakes = engine almost cutting out?
(In Topic #140593)
![0b1dhobi in the usergroup ‘Local’ 0b1dhobi in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
plumbed up ok no leaks. Second, i have bogg bro manifold with r1 carbs, now the issue is when i press the brake pedal it almost hits the floor if i pump it it hardens up (need bleeding?) but worst is the enging almost cuts out whats happening?
Run engine, then turn engine off
Pump the brakes a number of times then hold your foot on the pedal
With your foot still on the brake pedal, start the engine
If the servo is working, the pedal should go down a little bit more.
![Avatar](https://i1096.photobucket.com/albums/g329/baggie1005/SDC10038-1-1.jpg)
![baggie in the usergroup ‘Old timer’ baggie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
baggie said
whats the name of the box that attaches from the vacuum pump? the one with the diaphragm?
What engine? No petrol Mk1s have a vacuum pump except some USA and other ones but that's for emissions reasons not braking. Not sure on diesels though.
I have a German one, but it should be the same as the UK one
![Avatar](https://img585.imageshack.us/img585/1971/folderoh.jpg)
![BoomBip in the usergroup ‘Local’ BoomBip in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
<a><img></a>
baggie said
Really? ok what contains the Diaphragm for the fuel
What engine?
