my mk1 golf will not idle!!
(In Topic #140317)
![cjames94 in the usergroup ‘Regular’ cjames94 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
fuses are fine
all leads are on
got fuel
chokes working
how can i sort this? and fast
it will drive fine but when i stop at a junction clutch down with no accelerator it dies!!?
then other times it will be fine? any ideas?
![ratlenroll in the usergroup ‘Local’ ratlenroll in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
try turning it half a turn at a time
Bobby
could new plugs and leads sort this?
![fonzooorooo in the usergroup ‘Local’ fonzooorooo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![fonzooorooo in the usergroup ‘Paid Member’ fonzooorooo in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
ratlenroll said
your idle screw on the carb needs adjusting
^note that reads IDLE screw, NOT mixture screw. The idle screw only affects mixture/throttle at idle - no difference once the revs rise.
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi44.tinypic.com%2F2dt3fki.jpg)
![kayleigh.rayne in the usergroup ‘Local’ kayleigh.rayne in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
You will be surprised Lol. Simple engines, simple faults.
![oli_92 in the usergroup ‘Regular’ oli_92 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Re: my mk1 golf will not idle!!
cjames94 said
i have no idea wats up with it!
fuses are fine
all leads are on
got fuel
chokes working
I am having the exact same problem, i just cannot get it to idle. Did you manage to sort the issue and if so what was it? I have had the carb apart numerous amounts of times now, these o rings? would these be included in a carb rebuild kit? if this is the case then this is surely the only option? i have replaced the flange between the carb and the manifold thinking there was a possible air leak. and made up a new gasket for the carb body so the only thing left to do now would be to buy a kit and just rebuild the carb?! Any Ideas?!!?!?!?! PLEASE! ha
O.Bendall
![Avatar](https://i11.photobucket.com/albums/a156/danH73/Vwgolkfmk1.jpg)
![dan_73 in the usergroup ‘Paid Member’ dan_73 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![dan_73 in the usergroup ‘Local’ dan_73 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Rusty Hookers Dub Club
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Or, there's a vacuum issue - check the vacuum diaphragm on the back of the distributor for functionality.
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/179image.jpg)
![m00 in the usergroup ‘Paid Member’ m00 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![m00 in the usergroup ‘Old timer’ m00 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/1091194_496446640446608_699519234_o%20-%20Copy.jpg)
![TrialsRider in the usergroup ‘Local’ TrialsRider in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I got a rebuild kit for the original carb (solex pict7)
changed all the diaphrams, o rings etc, cleaned everything out with a decent carb cleaner, changed the carb/intake gasket, and its been sweet ever since!
I think mine was mainly due to crap being inside the carb ( previous owner let her sit for ages so there were fuel crystals )
