Lets see your 02S conversions
Many been carried out?  Would like to see how youve gone about it and what starter flyweel and clutch you used?
im about to go 02R but not looked into anything yet,got a hydraulic to cable conversion off a seat to fit though
Bert
Thats not a rod knockin,its a diesel stupid! floppy top and 1 tin top
02R?  I cant use the cable conversion thingy on mine a there is not enough room so have to go down hydraulic route, which to be fair I dont mind, was just been lazy!!!
 :lol:  lazy is fine  :wink:
02R polo 130 pd tdi 5 speed cable change box
engine and box going into a mk1  8)
Bert
Its all about 6 gears
Careful when ordering a slip diff for it tho, my mates just done £500 in cold blood from peloquin in states only to find out theres 2 different types, got to send it back and buy another!! whoops!
I was advised away from the 6 speed box, it is just too wide and too heavy.
I hope that's a Limited Slip Diff !!
Cheers,
Ade
6 speed 02S is not far of a 02J and not much heavier either.  No ltd slip diff either
my 02s conversion with peloquin diff, there is over 20,000 miles on it now
Fitting A Peloquin Diff To An O2j Box | Volkswagen Automobiles Forum
Inaris silver series 1. APX 1.8T REVO software, hybrid O2J/O2S 6 speed, peloquin diff, cabrio drives, toyota pas, 7.5x16 5X100 compomotive mo flatspokes, G60 ABS, 305 brembos octy vrs rears, coilovers and arb's by H&R
What selector mech did you use with your box syncro, am I assuming mk4 flywheel & clutch?  Also what pedal box did you fit to your mk1 as im assuming you went hydro as I cant get the seat cable thingy to convert it to fit.
I used a mk4 golf gti 5 speed gear shifter, i used a corrado g60 flywheel and a helix autosport vr6 clutch. i used a clutch master cylinder from rally design and made a bracket to attatch it to the steering column inside the car
thought you could only use a 6 speed gear shifter on a 6 speed box?  That hydro clutch looks complicated, any reason you went that way instead of fitting a pedal box from say a passat b4 or summin?
edited:is that a dbw tp I see?
Thats the norm for the mk1,other pedalboxes would be even more work to fit
ps what size master cylinder did you use, and wheres your fluid line feed going into?
i cant remember the size but there were 3 sizes available and i picked the mid size one, the resevoir is mounted by the wiper motor
