Confusing coil wiring
(In Topic #138466)
![DUBnutter in the usergroup ‘Paid Member’ DUBnutter in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![DUBnutter in the usergroup ‘Local’ DUBnutter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
The coil should have a black wire on one side and a black/coloured and black wire on the other. On mine I have 2 black wires on either side
I swapped them over and now when I try to start the car the rev needle jumps up and down a little which I think it should do. Nothing else has blown and seems normal. I found the timing is completely out on the dizzy so can't tell yet if swapping the wires on the coil has caused any misfiring issues!
Any help would be great!
-ve/1 side should have red/black and/or green wires.
if it helps most bosch coils have 3 pins on the + side, and 2 on the -ve. but actually look at the coil to see if it has any markings
If I do get the wires round the wrong way, what will happen?
Cheers for the help rubjonny!
The only thing that happened when we tried to start it for the first time after the engine being rebuilt and reinstalled, was a fuse popped and the fuel pump relay packed in-was a fair bit of smoke too
I just don't want to blow anything else up if I get it wrong, so at the moment im bridging the relay to get it running all the time whilst trying to start the engine.
Yes it is electronic ignition. The car is an 87 Cabby GTi with the DX engine code.
Going to give all the suggestions a go on Sunday and hopefully get her up and running after a 2 year break
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_2611%20%281%29.jpg)
![mk1ad in the usergroup ‘Local’ mk1ad in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:dry:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/dry.png)
![oubaastrompie in the usergroup ‘Newbie’ oubaastrompie in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Sent from my SM-A217F using Tapatalk
Re:
Have 2black wires on +side of coil and green and red with black stripe on the - side but red/black wire is my Rev counter wire but coil get very hot after a whilerubjonny said
you should have black wires to the +ve/15 side, if its points ign there will be a purple white wire as well on the + side.
