What can I fit from mk4 gti?
(In Topic #137339)
![Ice_Golf in the usergroup ‘Regular’ Ice_Golf in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
What do I need to change out and what do I need to adapt?
Also, I have a 4speed box in the car, what do I need to do to fit the 5speed? How do I connect the stick to the new box? Do I need a new stick?
I'm VERY new to this and finding info on this here in Iceland is not very easy…
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
1982 Mk1 Golf C in restoration
![Avatar](https://i924.photobucket.com/albums/ad88/blrh93/avatar.jpg)
![blrh93 in the usergroup ‘Local’ blrh93 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
for front brakes you could go for 280mm g60 brakes
or get some racing calipers e.g wilwood
you will need to scrap the 4 speed gear linkage and if you are using 1.8t i think you will need the cable shifter from your donor vehicle
track is way wider on the mk4 so shafts no good, front brakes wont go without a lot of effort, far easier to do the vauxhaull brake mod. rear calipers will go on with mk2/3 carriers and custom flexi lines, but make sure you install a bias valve
either way your old shafts wont work, you'll need mk1 gti if box has 90mm flanges, or late cab/rocco 100mm shafts if it has 100mm flanges
