Tachometer Golf MK3->MK1
(In Topic #137111)
![Avatar](https://img839.imageshack.us/img839/6316/avatarars.jpg)
![sanica in the usergroup ‘Newbie’ sanica in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Anything is possible, though I doubt it will be easy to get that to work in the Mk1…
My Build Thread
MK3 has a speedo sensor which will drop right into a mk1 box, just a case of getting the right one. if 020 box in the mk1 then you need 1.8-2.0 8v mk3, if 02a then you need 16v/vr6 mk3, if 1.0-1.3 then you need a 1.4 mk3. then wire up the sensor, brown is earth, black is live, blue/white is speedo signal to the dash.
for the rev counter you need electronic ignition, so if its a later model you're all set. if not get the bits you need from a mk2 golf to convert it! then run the mk3 revo signal to the TCI unit pin 7 job done
although… what i forgot is the final drive. mk3 sensors are all red gear type, so if box needs a white or green it will be out. you might be able to swap the gear over though but ive not tried that.
