Jellybellys LD Diesel Front end resto begins!!
![Avatar](https://i55.photobucket.com/albums/g160/r1-matt/mAtts.jpg)
![Matt in the usergroup ‘Old timer’ Matt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Jellybelly has joining the Turbo Diesel Club!!!
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg1.jurko.net%2Fuploaded_70725001942aa6734990be.gif)
![DubPartz in the usergroup ‘Local hero’ DubPartz in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
DubPartz
DubPartz
jellybelly said
if you need a hand with the wood i can machine you some new stuff
just need to wait for my grandad to finish my feet then it will be going on![]()
Great stuff, will give you a shout. Thanks
DubPartz
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
New ICE install
![](https://vwgolfmk1.org.uk/uploads/pbextract/1114992/P1100440.jpg)
and this weekend i have been getting it ready for the daily roads
hopefully i've been told correct
Before:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1114992/P1100437.jpg)
After:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1114992/P1100439.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1114992/P1100436.jpg)
also bought from the states a Girling caliper rebuild kit
![](https://vwgolfmk1.org.uk/uploads/pbextract/1114992/P1100435.jpg)
enjoy!
![Avatar](https://i52.photobucket.com/albums/g19/blans/Various/rsz_1frontgolf_zps6cddabf6.jpg)
Twitter Manager
![blans in the usergroup ‘Paid Member’ blans in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![blans in the usergroup ‘Old timer’ blans in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![regcheeseman in the usergroup ‘Local’ regcheeseman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Just a thought on your brake issue - you have the diaphragm vac pump which is notoriously bad. Perhaps you have very little servo assist?
I am not going to be too far behind provided the Guru has is blessing on Feeby :mrgreen:
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
well stanford hall didn't go so well as i broke down on the M1
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100443.jpg)
not good times
got it home and did a compression test and something wasn't right
so the engine came apart
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100533.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100534.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100536.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100540.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100541.jpg)
cyclinder head off and on the bench
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100542.jpg)
normal cracks inbetween the valves
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1100545.jpg)
and this crack around the injector housing
![](https://vwgolfmk1.org.uk/uploads/pbextract/1139867/P1110453.jpg)
so after it sitting in peices for a few month while prparing for the AGM, now it's over the rebuild will begin
The engine had a lot of life in it still
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Twitter Manager
also big thanks to GSF Leicester for helping me source all the parts i needed. Finding piston rings for these deisels is a bit tricky unless you wanna pay £200+ from VW
so after my holiday this will be going back together
pistons all cleaned up ready for the new rings
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110726.jpg)
new rings fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110730.jpg)
the bore before the honing
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110729.jpg)
then after a quick hone almost as good as new
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110731.jpg)
heres a bit of a problem
the top of the block looks like this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110734.jpg)
but then the gasket looks like this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148201/P1110736.jpg)
seem theres a few holes missing in the gasket and they are also not as big as the holes in the block
what you rekon???
Twitter Manager
http://www.jorily.com/catalog/index.php?main_page=product_info&cPath=132_109_110_126&products_id=1174
and my pic
![](https://vwgolfmk1.org.uk/uploads/pbextract/1148208/IMAG0145.jpg)
