Golf Gti -1979
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Frejsa.nu%2Fforum%2Fimages%2Favatars%2F2488044da2685e4b79.jpg)
![boonzo in the usergroup ‘Regular’ boonzo in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Golf Gti -1979
![](https://vwgolfmk1.org.uk/uploads/pbextract/1132642/058.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1132642/020-10.jpg)
And I'm not finished yet! The doors will be white, etc
And the litle golf got a new litle friend in the garage too!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1132642/071-1.jpg)
Golf 1,6 GTI 1979
![guga18 in the usergroup ‘Newbie’ guga18 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Hurry up with the gti :mrgreen:
But I've got some stuff home and i have started with the brake pipes anyway..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/073-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/004-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/019-2.jpg)
Now it's only coilovers that are missing, but it will take a while..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/018-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/001-6.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/3-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/069-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/088.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/009-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/003-6.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/022-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/037-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/068-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/010-8.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/015-6.jpg)
And I bought a complete 1,6 GTI EG engine from 1981 with 5 speed gearbox, which I will touch up and put in the car
instead of building one ..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/1-7.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/2-4.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/3-3.jpg)
4 speed and 5 speed!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/4-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/5-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/6-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/7-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/8-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1138055/9-1.jpg)
Regards!
Tommy
Golf 1,6 GTI 1979
Its writing in Swedish, but there are some pictures anyway!
http://www.garaget.org/forum/viewtopic.php?id=195407
And here`s also a thread about my 1976 Scirocco TS.
http://www.gtiklubben.nu/forum/showthread.php?14886-Scirocco-TS-1-6-1976
Just in case i forgot to update here….
Golf 1,6 GTI 1979
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I can't wait to take the golf off the road so I can get something like this done, although probably not to this level of detail!
:clap:
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/10-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/11-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/038-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/001-7.jpg)
I also picked apart and clean the oil pump and measured the clearance in it, and it all looked ok!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/14-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/15-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/12-2.jpg)
And first I put all things back to the original top…
But then I changed my mind and switch to a vented(?) top with an enem G6 camshaft (288 degree)!
Heres the original top on:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/13-1.jpg)
But first i put back som new fuel lines in the engine bay.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/00.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/3fd2ea96.jpg)
a new sensor
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/028-4.jpg)
Fuel pressure regulator from a saab 900 T16 -1985 (the left one).
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/025-8.jpg)
And then I removed the original top
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/1-3.jpg)
On with the new cylinder head gasket.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/2-2.jpg)
And new top bolts.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/3-2.jpg)
And on the whit the other top .. it is cut out a little bit around the lifters so that the camshaft can rotate freely.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/4-1.jpg)
The original camshaft vs. The Enem camshaft.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/5-2.jpg)
Here I am in full action!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/6-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/7-2.jpg)
Here its shows that the channels are well vented (or whatever it's called in English??
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/8-2.jpg)
And a new waterpump and cam belt kit.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/9-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/10-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/033-6.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/031-5.jpg)
And then I got a little bit done with suspension
The old ones was not in good condition..
![:rolleyes:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/rolleyes.gif)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/1-13.jpg)
So they changed to a set of coils instead
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/2-11.jpg)
Even the old conrol arms exchanged for new ones.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/3-12.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/4-11.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/5-11.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/6-10.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/7-8.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/8-7.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/9-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/10-5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/11-4.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/017-2.jpg)
Then i fixed the 5 speed gearbox!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/026-4.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/036-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/063-4.jpg)
New clutchkit 200mm.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/006-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/039-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/042-2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/044-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/045-3.jpg)
Got some help from one of my little girls!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/051-4.jpg)
So now is the engine and box in the car anyway! But its much to do before i can test to start it!!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/064-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/067-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/068.jpg)
And finally, I have also ordered some 15x7" rims!
Drag Wheels DR-20 Offset:10
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/Drag-Wheels-DR20LO-Black-15-Inch.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1143426/DR20GLET10.jpg)
All for now!!
/Tommy
Golf 1,6 GTI 1979
![Dubwanabe in the usergroup ‘Local’ Dubwanabe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![brad_mole in the usergroup ‘Local’ brad_mole in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![LinusE in the usergroup ‘Newbie’ LinusE in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
o kollar först inlägget o ser att de e svensk reg skylt
klart ball bygga… varför projekt tråd här ? borde passat in på oijoij.com ju
/Linus
From sweden !!
![Tom-DL in the usergroup ‘Regular’ Tom-DL in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![DanChave in the usergroup ‘Local’ DanChave in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://i170.photobucket.com/albums/u273/foxymk1/4c562e71-99b8-4381-9a3b-a4fd488a04b4_zps153d729c.jpg)
![foxymk1 in the usergroup ‘Paid Member’ foxymk1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![foxymk1 in the usergroup ‘Local hero’ foxymk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Unfortunately, it has not happened as much with the car recently.
But I'll make a start soon again whit it!
After all, it supposed to be on the roads in the summer of 2012!
Golf 1,6 GTI 1979
![steveee in the usergroup ‘Local’ steveee in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![caddybill in the usergroup ‘Local’ caddybill in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Golf 1,6 GTI 1979
![Avatar](https://i1087.photobucket.com/albums/j470/ice281265a/ICE.jpg)
![teva in the usergroup ‘Regular’ teva in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
"Mk1 Golf Gti..all things to all men"
![](https://i1087.photobucket.com/albums/j470/ice281265a/Golf018-1.jpg)
![Avatar](https://img684.imageshack.us/img684/3443/phpk1gnnbam.jpg)
![vw-man in the usergroup ‘Local’ vw-man in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Remember, VW made the last car in 1992. After that they started making vehicles.
vw-man said
very nice detailed work but i would keep it original becouse not so many left…
Thanks!
But i have not made any modifications to the bodywork and will still have the original interior. So the modifications I made to the chassis, brakes, wheels, engine and so on can be replaced with original parts again if you would want to make it completely original sometime in the future
Golf 1,6 GTI 1979
boonzo said
Thanks!
But i have not made any modifications to the bodywork and will still have the original interior. So the modifications I made to the chassis, brakes, wheels, engine and so on can be replaced with original parts again if you would want to make it completely original sometime in the future![]()
yeep……
anyway…respect for quality works
mine gti 77 is bought from sweden
jatte mycket bill
