Kamei Retro Racer mk1 build
![fthaimike in the usergroup ‘Local’ fthaimike in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Not related but while i do this the fuel pipe coming up from the tank moves and a click is heard from within the metering head so sounds like the pump is doing it's job.
just a suggestion but is there anything else on the gearbox that needs to be earthed?
i know there is the reverse switch on there but thinking if i cannot get a good earth through the gearbox/mount would it be possible to move the earth cable from the mount and instead connect it from the starter motor bolt to the chassis?
![vw_tees in the usergroup ‘Local’ vw_tees in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
the bolt i mean is the large one at the back which holds the gearbox to the engine block, the bolt has a direct earth contact to the block itself which also means all the sensors which earth to the block will get a better earth too
I think i saw spare battery cables in my local halfords the other day otherwise i know of an autoelectrical place that might be able to make the lead.
cheers again
mike
p.s. talking about earths would that be why my oil pressure guage isn't going up much too?
can just see it here, the head is all clean and shiny where the earth cable was fitted:
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fcabby22.jpg)
actually you can see in the piccy both of the bolts are the stud type, somehow I ended up with 2 stud bolts and no non-stud bolts
N 907 016 04 - double stud with hexagon drive, M12x55/M8x10 - 2.05+VAT
as i say its on all mk3 1.8-2.0 so dead easy to pinch from zee scrappy
Just fault finding now hopefully to get her to fire.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1136989/P7190698s.jpg)
Also bought a longer new battery cable from halfords and earthed it from the new top bolt on the gearbox nearer the bulkhead that goes into the block like you said and the other end went where my horn was earthed where the battery tray would normally be.
Even though the engine doesn't fire yet the engine spins around off the starter motor quite happily without running battery down quickly.
