Which MFA, and does anyone have one for sale?
(In Topic #135450)
I have a early 91' gti cabby,
My MFA display doesn't work, it's is completely blank and I'm looking to getting it working again,
Everything else works on it lights, speedo, rev counter it's just the display that is blank.
I have do far purchased and sold on 3 mfa's as I keep buying the wrong ones lol.
The MFA I have has an extra plug behind the rev counter, which MFA do I need to replace the one I have? From which car as Im frustrated at buying ones that don't have this plug.
Does anyone have one they want to sell on?
Or is there a way to check my LCD and confirm it's defective and not the stale , as I have read this could possibly cause the MFA not to work?
Thankyou in anticipation for any help
Any idea where to start looking? MFA stalk? Does the lie come off the ignition live?
Can I rewire a new permanent live?
Thanks again
Do you mean the while unit itself?
The red wire, is it the one from the fuse box or a red one off the clocks?
Sorry I'm asking
try pulling the fuse for 30 seconds then refitting, this can sometimes sort it. also check the brown/white wire to the cylinder head this is the earth for the dash.
Going to check that now,
On the back of the clocks is it the main cable that goes into the bottom "big plug" connection that supplies the LCD screen?
Is that the supply to the LCD?
Also now tested pin 2 ( earth?) and getting a good earth there too
what do the pins look like, ive had poor contact problems caused by bent pins, and also worn contacts on the clock pcb. also on one of my clock sets the plastic clip surround was missing so the pcb would move around, that one was a right pain to get the pcb aligned right when plugging in
Thankyou for all your help.
What MFA do I need to look out for as a replacement?
Like I said I keep buying the wrong ones.
Mine has the red/white and black/white plug next to the rev counter at the rear.
The ones I keep buying don't have that connection.
So any advice on purchasing the correct one ?
Thanks again for all your help John
http://cgi.ebay.co.uk/MK1-Golf-MFA-Dash-Speedo-Clocks-Dials-Spares-Repairs-/180692271334
http://cgi.ebay.co.uk/MK1-Golf-MFA-Dash-Speedo-Clocks-Dials-Spares-Repairs-/180692272878
http://cgi.ebay.co.uk/mk1-VW-GOLF-GTI-CONVERTIBLE-cab-clocks-85-000-parts-/140571462350
Just brought the 3rd item .
Checked first and he confirmed it was fully working.
Fingers crossed it will work when I get it.
As this one has 87k mine has done 107k is it easy enough to change the clocks or am I best just leaving it?
Thankyou for the idea I've tried everything now for the last couple of months but to no success.
Just brought one off eBay and if this one doesn't work I'm gonna give up and accept it's just not meant to be lol.
best test the clocks before you strip them though
changing the mileage on the clocks is easy enough, but you still have to take the speedo out to do it so you may as well just swap the lot over. unless you fancy sitting there for ages with a drill poked in the back
Plugged them in hey prestow a working MFA ……
Now my dash lights work , but when I turn the ignition on and start the car they go out? Totally random any ideas?
Also when I turn the lights on ( no ignition) the oil light comes on but that goes out when the engine is running!!
Totally confused now I take it the MFA I have just received is also broken?
Is it possible just to change over the LCD to my old one?
Any help is really appreciated as this is now really annoying lol
