re boring 1.3 1340cc is it worth it?
(In Topic #135115)
![stroutsy in the usergroup ‘Local’ stroutsy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
sproutsy
sproutsy
![g40jon in the usergroup ‘Regular’ g40jon in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![JMRacing in the usergroup ‘Local’ JMRacing in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Cams… dont over-cam for road use, again, unless breathing is improved and c.r raised to suit.
The 1300 can be a good little engine tho.
www.jmrclubsport.com
sproutsy
One of the biggest problems is the std piston location… they are a long way from the top of the block, combined with a thick-ish head gasket it gives not only a low compression ratio but poor squish.
We looked into taller pistons from a different 1300 engine code to get them closer to the top, and then skim the block to do the rest. If you re-boring then the extra capacity is worth going for as the pistons are usually the same price or not much more.
sproutsy
Are they into robbing people up there!
A re-bore is £100, pistons should be no more that 200 quid… I can get custom forged pistons done for 600 quid and thats overkill.
Post up your engine code and I'll have a look at the std piston options if you like. I cant remember where we got to with the one down here, I'm sure we found a piston that was taller. The engine code will help as they vary a lot on the small block engines.."GF" is one that springs to mind.. some have flat heads, some chambered with obvious differences in pistons.
sproutsy
Stamped on the block, or, you should find it on your logbook doc. It'll list the engine number, in amongst that number will be the code.
sproutsy
sproutsy
![trevmk1oldschool in the usergroup ‘Newbie’ trevmk1oldschool in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Re boring 1.3 1340cc is it worth it?JMRacing said
WHAT!!! 2K!
Hi bought an 1984 mk1 , have been spending lots of money on it.
It is a 1300cc Donkey. want to make it faster.
I am new to motor mechanics, no idea about what makes speed.So mind the mistakes wth the language or terms just relaying what I have been told.
I have had suggestions to go 2ltr ABF ,, etc
I have met an old man(engineer) who wants to assist me
Bore it to 1340, bigger carrevelle, Balanced pistons, shortened conrods , as the blocks been cut,1600 head, with cam
Turbo, with throttle bodies, dual injector system, branch, intercooler.
Carbon Fibre Button clutch, thinned flywheel.
New engine mountings.
DRY SUMP! with a can in boot for oil.
He says this car wll be racing quick. 300 bhp
Could this be true or is he trying to rip me off?
There's a reason why people tend to gravitate towards the well-known engine conversions such as 16V, G60, 20vT. There's a lot of parts available off-the-shelf from scrappies, there's a lot of info out there on how to make it work, look neat, not cost too much and perform well. For example 300bhp is quite achievable with a chipped 20vT which started out as the 225bhp version. By all means try something different though.
![rubadubdub in the usergroup ‘Regular’ rubadubdub in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
stroutsy said
hi there basically my engine is knackerd its spitting oil from the breather and its the piston rings so i may be getting it re built the boys at my dads work said you may aswell get it rebored to 1340 and put a cam in itto make it abit nippier and a twin choke carb, obviously im going to need new pistons etc, is it worth doing? is there anything im forgetting
From your description it doesn't sound like the engine is too healthy. However, before you part with any cash for rebore/new engine I'd definately do a compression test to confirm what's going on inside the engine you've got.
Not so much ripping you off but talking rollocks!
A decent 1300/1340 can be built with a ported head, cam, nice exhaust, and not cost the thousands yr man is dreaming about!
The above would still be insurance friendly. Or you could look at an 1800-2ltr 8v conversion…decent grunt, loads available, cheap.
Or as suggested maybe a 16v conversion…plenty of 1800KR or 2ltr 9A/ABF engines about…all work well and would be a big jump from the 1300….and can be further tuned for more perfomance without spending a fortune…a real world 140-180hp in a Mk1 Golf is a quick car for sensible money.
![blenki in the usergroup ‘Regular’ blenki in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Seams very ambitious, can't help but thing a 1.8t conversion would be cheaper
