Engine Problems
(In Topic #135242)
![alihazlak in the usergroup ‘Regular’ alihazlak in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Engine Problems
Yesterday when i had a 150 mile journey home, after about 50 miles there was some jolting at around 65 mph. I couldnt change down a gear as the jolting got worse and then the engine cut out. I pulled over and left the car for a minute or two, started it up and drove on fine for around for another 50 miles or so and then it happened again. Therefore i pulled over and turned the car off and drove off again. However the car then stared jolting again after about 10 miles and i could only drive in 4th gear. The jolting then continued and i pulled over and then the jolting wouldn't stop and i only managed to just get home in 2nd gear !! This morning i turned the engine on and it ran for a few minutes. I then turned it off and it wont know turn on. It fires up fine, hits about 1,000 rpm but if i leave the accelerator it dies straight away. If i keep my foot on the accelerator it doesn't die, but as soon as i let go it dies. Does anybody have any idea about what could be happening ?? Any help would be much appreciated. Ali
James
At some stage, you couldn't select any gear except 4th. Then at some further stage, you couldn't select any gear except 2nd?
The car starts, runs but then cuts out unless you keep your foot on the accelerator?
Did both of these issues just occur, or is there any history we should know about (how new is the car to you)?
How did you test and discover the car is "rich"?
Smell is a reasonable indication, fuel consumption is a bit vague to tell what the engine mixture is, and at what running condition. So its best to get it checked properly for mixture, eg by using a gas analyser. If you're feeling lucky, you could tweak the mixture down a little bit, but it would be chance, not good workshop technique, if that fixes it.
There's a FAQ on carburettors which will help you out including pointing out the mixture screw and solving auto-choke problems. If its the original carb then they are prone to wear and produce running issues as a consequence.
i dont think the heater would make that much of a difference, especially now its warmed up a bit. first thing to check out when you get carb icing is the warm air system as it has a much bigger impact if not working. still, worth keepign an eye out for a heater, in fact GSF may even sell them? also make sure the earth from the carb body to the rocker cover is there otherwise the heater wont work once fitted
if you take the airbox off but leave the vac line plugged in, you can look down the end of the warm air housing to see the flap. get a helper to start the car and check the flap opens, if it doesnt then either you have no vacuum or the flap unit is bust. what you could do in the short term is push the flap open 3/4 then thread a self-tapping screw thru the side to wedge it there till you get it fixed.
i would also be on the lookout for a working heater unit
![fthaimike in the usergroup ‘Local’ fthaimike in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
with my carb engine there was rust flakes coming off my pipe from the fuel filler pipe and these would get into the carb, i lifted the airbox off the top of the carb and put a tiny bit of petrol into the carb turned the key and it fired so i ended up getting a stainless steel pipe.
the other time was on my injection engine and there was a fault with the fuel pump relay, i would be driving along and then you could feel the power dying and if i kept my foot down it would gradually loose speed until it came to a stop and the rev needle would drop then stall, i tested it by jumping across the relay and it started and drove fine so had to replace the relay.
early style coil/cap has just a plain hole with a copper ring round the outside, late style has a pin in the middle of the hole. get your new coil and check it, then get the leads and cap to match
![andi71 in the usergroup ‘Newbie’ andi71 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
