mk1 20vt and mk1 PD
![veeduben in the usergroup ‘Regular’ veeduben in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
mk1 20vt and mk1 PD
Ben
![mkoneman in the usergroup ‘Local’ mkoneman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
veeduben said
hi mate - awesome build - quick question - is the coating you used for the engine mounts and rocker cover etc a textured black powder coating or a paint? wanting a similar finish on my wheel centres.
Ben
hiya mate its paint made by VHT
few more parts collected today
another self sealing hose joint to help with the mounting of the forge 007p
![](https://vwgolfmk1.org.uk/uploads/pbextract/1123334/IMG-20110524-00117.jpg)
a new high powered 11' fan that i will be mounting in oe housing
![](https://vwgolfmk1.org.uk/uploads/pbextract/1123334/IMG-20110524-00114.jpg)
both available from www.revotec.com.
a 3' silicon joiner for mounting the air filter
![](https://vwgolfmk1.org.uk/uploads/pbextract/1123334/IMG-20110524-00116.jpg)
with the air filter mocked on (not in final position)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1123334/WestOxfordshire-20110524-00113.jpg)
and a random front end shot
![](https://vwgolfmk1.org.uk/uploads/pbextract/1123334/WestOxfordshire-20110523-00110.jpg)
![](https://www.vwgolfmk1.org.uk/images/banners/cqpartner.jpg)
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
so spent a few hours making the rear gearbox mount
this is the finished gearbox half of it using a polybush
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124352/WestOxfordshire-20110528-00123.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124352/WestOxfordshire-20110528-00124.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124352/WestOxfordshire-20110528-00125.jpg)
then i finished off the welding on the body half of it, just needs a lick of paint now 8)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124352/WestOxfordshire-20110528-00121.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124352/WestOxfordshire-20110528-00120.jpg)
the mount is hidden under the gearbox for a cleaner look and should help with reducing engine movement
instagram: mkoneman
![](https://vwgolfmk1.org.uk/uploads/pbextract/1125137/WestOxfordshire-20110531-00136.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1125137/WestOxfordshire-20110531-00134.jpg)
also got the dv mounted almost straight out the turbo back in 8)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1125137/WestOxfordshire-20110531-00132.jpg)
engine bay is about 90% done now
instagram: mkoneman
![alexHxC in the usergroup ‘Old timer’ alexHxC in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
just thought i'd let you know a mate of mine with a mk3 golf conversion i made an AUM loom for plugged the ecu diagnostics wire direct to his vag-com port and it worked
fan housing…. done
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128386/IMG-20110614-00158.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128386/WestOxfordshire-20110614-00160.jpg)
vacuum line ….done
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128386/IMG-20110614-00162.jpg)
and all the bits to finish the clutch 8-)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128386/IMG-20110614-00156.jpg)
instagram: mkoneman
i have the fuel lines, down pipe, drive shafts to fit, finish making the interior loom, now waiting for matching silicone top and bottom rad hose in black 8)
then when its all up and running ill flash the custom map onto it :wink:
then loads of other little bits to finish
instagram: mkoneman
![oliverbeer in the usergroup ‘Newbie’ oliverbeer in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
i dont personally as i dont have a premises…..yet
altho i do do a bit of work for crazyquiff who are more than capable of doing any engine conversions :wink:
instagram: mkoneman
new fuel pump, lines, hardware, wiring and a stainless steel crazyquiff bracket
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128905/IMG-20110616-00174.jpg)
new braided line to the fuel rail with earl hose ends and ally separators and mounted to the cambelt cover (black cable ties will be replaced soon)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128905/IMG-20110616-00177.jpg)
new VAG oil filler cap
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128905/IMG-20110616-00175.jpg)
and a over look of the bay at the end of tonight
![](https://vwgolfmk1.org.uk/uploads/pbextract/1128905/IMG-20110616-00179.jpg)
instagram: mkoneman
![Damo516 in the usergroup ‘Regular’ Damo516 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Dubwanabe in the usergroup ‘Local’ Dubwanabe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
lil update
I got my crazyquiff/longlife down pipe. I made a few tweaks to it so i was happy then I wrapped it sealed it and fitted the wideband lambda
![](https://vwgolfmk1.org.uk/uploads/pbextract/1132092/WestOxfordshire-20110630-00205.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1132092/IMG-20110630-00207.jpg)
instagram: mkoneman
![Avatar](https://i875.photobucket.com/albums/ab313/peterg60/mk1_zpsbfbbd7be.jpg)
![peterg60 in the usergroup ‘Old timer’ peterg60 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/10avatar.jpg)
Design Manager
![Joe90k in the usergroup ‘Paid Member’ Joe90k in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Joe90k in the usergroup ‘Old timer’ Joe90k in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
mkoneman said
thanks for the comments 8)
lil update
Still looks as good as ever James, Are CQ selling these? Why is it "longlife" as you say? Also have you fitted any sort of fuel filter?
Joe
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg.knighting.co.uk%2Fuploaded%2Fgolf%2Fsignature.png)
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Joe
cheers mate yeah they are selling them they are built by longlife custom exhaust company for cq, i have fitted a fuel filter up in the scuttle 8)
had part one of 2 packages turn up today :wink:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1133263/WestOxfordshire-20110705-00218.jpg)
instagram: mkoneman
Design Manager
mkoneman said
the wheels are custom built to my spec direct from work
Joe
haha oh :redfaced: didn't realise that was the companies name! I was wondering why the lines went up into the scuttle.
Whats the package for?
