16v Drag Project
(In Topic #134469)
![the-hairy-one in the usergroup ‘Newbie’ the-hairy-one in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
16v Drag Project
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/newgolf002.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/_MG_0056.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/_MG_0057.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/_MG_0055.jpg)
Here we were planning to tilt the ABF motor forward. We're using huge Jenveys, and that meant we'd have to cut the bonnet. So we tilted the damn thing.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin1.jpg)
Tinted lexan fitted, as well as the carbon side mirrors, single Audi S3 handle, raised bonnet for cooling etc..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin5.jpg)
Interior odds and ends…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin6.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin4.jpg)
Engine is a special one, the head has 300deg cams and everything has been tinkered with. Bottom end has been balanced with a 100mm Eurospec crank, JE pistons, rods, 14:1 comp…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin11.jpg)
Jenveys!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin10.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin8.jpg)
H&R and Koni combination
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin9.jpg)
Hydraulic handbrake…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/muffin7.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0066-1.jpg)
Custom made aluminium fuel cell…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0093.jpg)
…mounted to the car.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0087.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0098.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0082.jpg)
Adjustable struts towers…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0057.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0071.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0089.jpg)
Huge ass cvs'…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/IMG_0063.jpg)
Lightweight rear axle made from aluminium.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011025.jpg)
Checking for space…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/DSC01006.jpg)
Oil catch pans are required in South African drag racing rules.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011041.jpg)
Long manifold runners.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011033.jpg)
Check the MkV alternator!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/DSC01009.jpg)
52mm Jenveys!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011037.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/DSC01007.jpg)
Aeromotive takes care of the fuel.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/DSC01002.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/DSC01003.jpg)
Engine tilted, with Jenveys facing frontwards through the grille, and not out through the bonnet.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011036.jpg)
How low can one go?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/Racingcars2011034.jpg)
4-into-1 exhaust system exiting through the fender
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/788ba505-797e-4c2b-9007-5174f5bf8894.jpg)
Weld Racing rims with M&H drag slicks, with skinnies for the rear. Now the sideshafts can finally be measured up and manufactured.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/5b2122fd-17d6-4706-be7a-8b110678bbc1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/2c67daa2-9194-4278-801c-ca8084816c9a.jpg)
Finished! The car just needs a few adjustments like the new updated decals, corner weights and final dyno tune.
Ready for war!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/side.jpg)
Hows this for a fender?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/engine.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/engine2.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/radiator.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/engine1.jpg)
Guages - check!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/wheel-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/seat.jpg)
Lightweight Welds…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/skinny.jpg)
Brake drums drilled for weight loss…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/brakes.jpg)
Thanks for the help boys…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/vinyl.jpg)
Off to Koni to do the corner weights
![](https://vwgolfmk1.org.uk/uploads/pbextract/1124543/loading.jpg)
Our first event is happening this weekend. Obviously we'll have a few hiccups but we all have to start somewhere…Hope you enjoyed our build.
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Favatars.jurko.net%2Fuploads%2Favatar_22610.jpg)
![smokeybubbles in the usergroup ‘Local’ smokeybubbles in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1GTi
Rallye Golf
Mk5 GTi
Mk7 GTD
Rallye Golf
Mk5 GTi
Mk7 GTD
![boyle_sbd in the usergroup ‘Local’ boyle_sbd in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mk1 golf - resto
mk3 polo breadie - daily banger
![GTInCyprus in the usergroup ‘Local’ GTInCyprus in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
What's the weight and power?
Awesome build. Prob could be made road legal fairly easily too! (Minus the mental exhaust of course!)
My Build Thread
![Dubwanabe in the usergroup ‘Local’ Dubwanabe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Gazvenn in the usergroup ‘Old timer’ Gazvenn in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
