gti cam in 1.8carb engine
(In Topic #132886)
![hank1 in the usergroup ‘Newbie’ hank1 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
would a gti cam fit into a 1.8 carb engine? would this make any difference?
i have a clipper with a weber carb conversion on it, i would like to make more of the standard setup.
ian
![Avatar](https://i1108.photobucket.com/albums/h417/chris_hall1/avatar1_zps7e5dd51f.jpg)
![chris-h in the usergroup ‘Old timer’ chris-h in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I have no idea what gains this will have over a clipper's cam.
When I had mine in bits I fitted a secondhand KENT CAMS GS2H fast road cam to my clipper. As this is an upgrade for a GTI/any 8v engine I opted for this. Bought secondhand for about £90.
Not had it on the rollers for setting up as yet, but hope to later in the year. I hope to see a respectable increase, especially with the Dellorto carb ann new exhaust.
If you do change the cam, then it's a good time to put in a new set of followers. If you do buy a "hot cam the a vernier pulley will help get the best out of it.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
That's what the "H" in my cam spec means.
Mine is hydro on a 1991 ( H )
![Downster32 in the usergroup ‘Old timer’ Downster32 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
