any one done a rear disc conversion on a mk1 golf?
(In Topic #132707)
![Avatar](https://i1183.photobucket.com/albums/x467/cossie69/mk1Timmy.jpg)
![mk1Timmy in the usergroup ‘Regular’ mk1Timmy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![smokey_gti in the usergroup ‘Local’ smokey_gti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![walsallboy in the usergroup ‘Regular’ walsallboy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
You will need
Disks
Pads
Inner and outer bearings and grease seal
Outer dust cover and new split pin assembly
Back plates
Inner dust covers
Caliper and carriers
Mk2 stub axles
Handbrake cables to suit, the original 16v Scirocco ones only fit properly in the hangers with early mk2 calipers, they are ok for the later ones but you have to hang them on modified hangers or cable ties. If you go for mk4 calipers then you will need the special C&R ones at £££
Spring clips to hold the handbrake cables to the calipers.
Flexible hoses, Goodridge 6 line kit or C&R ones for mk4 calipers.
Brackets to hold the caliper flexible hose to solid in place, modified mk2 items work.
Fluid
Either GTI rear compensator or inline late cabby pressure regulators, you must have one of these otherwise you will over brake the rear and be in danger of spinning out of control - also be aware that some earlier cars had what look like pressure regulators in the engine bay, they are simple one way valves !!
Brake pipe, ends and flaring tool for the new solid pieces from the flexible hoses above the axle.
Thread lock for the stub axle bolts and carrier bolts.
the ones to get are the later style MK3 calipers without a spring on the outside, the early MK3s used MK2 calipers with the external spring. MK4 work fine but you need conversion cables, and they arnt any better than MK3s anyway so its just an extra expense over MK3s for no real advantage
![Avatar](https://i9.photobucket.com/albums/a55/laughingboy_1978/a3e1cf5a-b37d-466e-b185-aad4fb4a558e.jpg)
![Laughingboy in the usergroup ‘Local’ Laughingboy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
lhasadreams said
…Either GTI rear compensator or inline late cabby pressure regulators, you must have one of these otherwise you will over brake the rear and be in danger of spinning out of control - also be aware that some earlier cars had what look like pressure regulators in the engine bay, they are simple one way valves !!
You wouldn't know which years came with those pressure regs would you?
Mines a 1990 and has some kind of valves fitted under the master cylinder. Wasn't sure what they were to be honest and if they would be needed for my 22mm master/9" servo and rear disc conversion.
Website Manager
Rear Brake Pressure Regulator (load sensitive) 841 612 151 >> F 15-E-011 290 - This is the one connected to the rear axle
Brake Pressure Regulator (pressure sensitive) 533 612 151 F 15-E-011 291 >> (also use 411 611 789) - You need two of these and they are screwed into the master cylinder
What is your chassis number ?
Something like
WVWZZZ15-E-011291
Where the dashes have letters in them that are not significant to work out which cars had them.
Are yours screwed into the master cylinder ?
Website Manager
The later cabby pressure sensitive regulators that screw into the master cylinder are the same as the 16V Scirocco ones, just checked again on ETKA and they are the same part numbers.
You are thinking of the check valves that were fitted between the master cylinder and front pipes in the engine bay on some tin top GTIs, they come as two pieces, part numbers 171 611 789 and 113 611 191.
I can confirm that the late cabby pressure regulators do not hold any residual pressure.
Website Manager
I wonder what the bias difference between them is ?
When doing this conversion I always use a 22mm master cylinder and 9" servo, along with the 256mm calipers/Audi Carriers.
The wifes car brakes very well and not a hint of over braking from the rear. It has passed 2 MOT's with this setup, so that leads me to think that the cabby pressure regulators work well with this setup.
Ever thought of running some pressure tests on the valves you have to really see what the difference is ?
