rear seat catch right hand from rear of car is missing??
(In Topic #132076)
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
some pics below as seen from the rear so you can see the mechanism, one with the boot lever in and one with it out.
hope that helps.
1988 1.8 carb Golf Clipper
or put it another way there is no inter lock between the passenger side release and the drivers side
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
the seat locks to the car with 2 metal hooks on the back of the seat into square holes in the body, make sure both hooks are there and they move when you tug the rubber loop. if its not lockign down adjust the rubber buffers behind the seat to adjust the tension on the seat when its locked down, if too tight it wont catch, if too loose it will rattle all over the place. also if not ajusted properly the boot lock function wont work right and you wont be able to fold the seat even if its released
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
The clip on the drivers side is just self sprung, so moves out the way when then seta is pulled back. If its not making contact with teh square hole as stated try adjusting the rubber bummper also in one of the pics. If you need any more pics, dif angles etc just shout.
