clutch really stiff mk1 gti
as title really im in deperate need of helf with my gti he clutch peadal is really stiff ive changed the realise bearing and the clutch backing plate cable seems ok also ,im totally stumped has any1 came accross this before thanks joe
I would try another cable matey i had a similar problem and although the cable felt fine when disconnected it had frayed inside.
A new cable sorted it straight away
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
How old is the clutch plate ?
They stiffen up a lot over the years, if it is not the cable then that is the usual reason.
Cheers,
Ade
the clutch plate ie the bit with the material tht wheres dwn or the bit with the fingers on
The bit with the fingers on.
Cheers,
Ade
have u checked the hole on the bulkhead where the cable goes thru
