Mk1 Golf Gti 83 Restoration Update 2/2/2012
(In Topic #129531)
Just a quick introduction before the mayhem begins, you might recognise the car as its from a previous owner on the forum (my brother Jon-boy). I'm about to take on the massive challenge of restoring her. I'm a bit of a dab hand at DIY and mechanics in general but have never taken on anything of this scale.
The direction of the build
I want to keep the car looking relatively OEM, no drastic external changes. I want to make the interior fresher and modern without losing the classic look. Finally the engine bay will have a clean up and possibly a further conversion .
The car a year ago :-
Heres the low down :-
She is in good nick but will require a bit of body work, I plan to strip it down and restore it bit by bit and finish it off with a nice fresh coat (not sure if I should keep it Mars Red though?).
The engine is sweet and was rebuilt 2 years ago.
The engine has been upgraded with a 2 litre Mk3 Golf bottom end, mk1 8v 1.8 gti head (heavily gas flowed and ported), wild cams and ported polished audi tt throttle body.
Areas that need work :-
Rust around the fuel filler cap
Rust on rear archs
Rust on rear valance
Rust spots on sills (needs further investigation)
Sun roof shot
G60 BBS wheels - require refurbishment
I have some brand new panels ready to go
foxy
Bit of rust along the glass seal but doesn't seem to be anything on the underside which is good.
No sign of rust coming through the tar covered floor but I will chisel that back this weekend to reveal any hidden tin worm.
When I pulled the aftermarket sound proofing back it revealed the primed floor, signs of light surface rust, hopefully not so bad once its been revealed.
Ah the sun roof, it was a complete state and not properly isolated from the roof skin. Will clean it back at the weekend but think a new roof skin may be in order
Finally the scuttle panel where the glass seal meets, think I might need to replace this bit lol.
The only major concern is the roof at the mo, there is a slight tear near the sunroof panel and rust that has penetrated from underneath to the top (only slightly visible from the surface).
If anybody has anything give me a shout.
This weekend I managed to get the car on my rotisserie frame. I've modified it with castor wheels so the whole shell can be pushed around the garage.
Managed to borrow dads air compressor and have loads of new air tools to play with
COTM Team
Well I've started to strip down the passenger side rear axle and sill assembly.
Progress is slow but hoping to pick up now as I'm confident my welding is good enough
Managed to get repair sections for the rear axle mounts from BBT, so decided to start on this first as seemed like a straight forward bit to do. Removed the underseal and general crude to get a better Idea of how it's built.
As you can see below there is quite a bit of corrosion in the inner box section, I removed a part of the sill to get a better look at the damage.
The axle section was relatively simple to remove once we discovered that the axle mount bolts were part of a separate reinforced section. Located the spot welds and drilled them out and air chiselled part of the panel off.
completely removed
Next i ummed and ahhed about removing the complete sill section, In the end I decided to remove most of the outer sill and discoverd it was like new , Oh well can't be a bad thing welding new steel in, at least I have peace of mind.
Once removed I started to repair the inner sill section at the front which was completely gone. Will need to make up a repair section for a tiny section of the floor to build up the sill before the outer sill is replaced.
Anyway this is a start, Wednesday have dad over to give me a hand.
New patch panel made.
New strut top made up and test lined up. Requires a bit more tweaking before the final welds.
Got a bit more to do, top of the strut needs a bit of attention.
Started treating and cleaning up rust.
Started cleaning up the front.
That rotisserie will mean welding will have so much better results
car looked good before you touched it , just shows you what can be hidden behind a nice looking exterior
keep up the good work
baz
cheers,sean
Rich
cheers,sean
With a lot of help from dad started to make some major progress.
Managed to get the axle mount repair fixed on the passenger side.
And then there was the drivers side!!
Can you see what it is yet?
To…
I had to remake the axle plate as it was badly corroded (pics to follow).
I have more pictures to come on this but this is the finished outcome:
Bit of a clean up on the underside but more to come:
