Starts then cuts out straight away (Video Attached! HELP!)
(In Topic #131213)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/10avatar.jpg)
Design Manager
![Joe90k in the usergroup ‘Paid Member’ Joe90k in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Joe90k in the usergroup ‘Old timer’ Joe90k in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I am trying to get a 1.8 GTi Lump running, I have checked it is getting fuel and the fuel pump is working and when the union is un-done that flows fuel into the metering unit it pisses out. (Although I'm not sure if its meant to be under such high pressure?)
Anyway, the car starts, sounds fine but just cuts out after 5 seconds. If you touch the accelerator it dies, it will start a couple of times then won't start again. If you leave it, it will start again in about 2 minutes but do the same thing as before.
I have taken a video. It also appears that a hissing noise can be heard from inside the engine bay and the pipe that leaves the inlet manifold, I have circled where I mean in the photo below:
![](https://img96.imageshack.us/img96/7599/49239242.jpg)
Video here:
(The engine running in the background is my A3 which is being used as a battery as the golf's battery is dead and needs a charge!) You can hear the hissing in the video.)
Cheers for any help!
Joe
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg.knighting.co.uk%2Fuploaded%2Fgolf%2Fsignature.png)
2018 Up! GTi 1.0 TSI
2011 Caddy Maxi Kombi 1.6 TDi
i think you have answered your own Q, you need to get the air leak in the induction pipework fixed , this leak will be stopping the metering head from operating correctly , the electrically operated cold start injector is probably causing it to fire briefly at the moment
baz
ps that battery is def not helping matters
Design Manager
Joe
its the non-return to create a vacumm in the servo , i think i know what hole you are talking about it supposed to be blanked off , just plug it with sealant on the surface .
the week battery will be causing all sorts of problems with the fuel supply , the volt drop accross the fuel pump will stop it operating properly when trying to start
baz
Design Manager
Joe
![satans_creation in the usergroup ‘Old timer’ satans_creation in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Im having the exact same problem
![Millergolfmk1 in the usergroup ‘Newbie’ Millergolfmk1 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
satans_creation said
Did you solve this my friend
Exact same problem with one I bought a few days back, starts when it wants too :/
