1976 Vespa Rally 200 Restoration - Complete
what did they use to strip the paint and oil off and where they expensive
have a look at the website.. its 5 mins from my house
http://www.paint-strip.co.uk/
they can dip an entire car 8O
yes you can get a vespa in a mk1 golf
all rust and paint will be gone soon! nothing will be hiding :shock:
1st pass at cleaning the engine, before and after
who wait ?
just the man I wanted to speak to.. read you thread and I'm after some ali clean for this project, didnt fancy paying £6 for delivery? did you pay for delivery? do you know of anywhere local that sells itandy-b said
She will be a looker when you get here finished,but there is no rush take your time, all good things come to those
who wait ?
Thats not that far away from you.
think i will bite the bullet
10 for ali clean 6 for delivery :x
What do you think on the Engine casing.. Ali Clean, Ali blast, then does it need the clear coat? it it ok at high temp?
is under hood black good at high temp too? thinking of doing my cowl in it
things like water pump,dizzy,on things like exhaust and inlet manifold i used a high temp paint
and powder coated the rocker cover and sump.As for the engine block i used por15 again a high
temp paint.That all said the gearbox was done with ali blast and diamond clear laquer. Hope this helps
got my frame back.. what do you think?
and also be more of a target for theives :x
hope its another 35 years before it needs some attention again
Looking good so far when does the prep work start for the respray,and what have you
decided to do with the engine casing and parts.
andy-b said
Hi mate,this is the first day i have been able to get on to the forums since the 12th,
The frame is still having some welding done, all the Ali Stuff has been blasted ready for painting
as for the casing I am gonna Ali Clean/ Ali blast, then is there a sealer/ laquer to use??
then it wont make any differance what you put over it.
was thinking the actual casing in ali blast and barrel in something like por15. gonna ring frosts this week to see if they can give any adviceandy-b said
Did you check out if ali blast will stand up to the heat from the engine because if it dosent
welding and blasting
i will see you there.
and some priming has been happening
