mk1 golf tfsi turbo the beast for 2011 and beyond!!!!!!!!!!!
(In Topic #130674)
![twain16v in the usergroup ‘Regular’ twain16v in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://i259.photobucket.com/albums/hh319/brucie_boy/Photo157-1.jpg)
![brucieboy in the usergroup ‘Local hero’ brucieboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![](https://i259.photobucket.com/albums/hh319/brucie_boy/sig-2-1.jpg)
![Dubwanabe in the usergroup ‘Local’ Dubwanabe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![brad_mole in the usergroup ‘Local’ brad_mole in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/140image.jpg)
![mike_turbo in the usergroup ‘Old timer’ mike_turbo in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![G60RGE in the usergroup ‘Old timer’ G60RGE in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i170.photobucket.com/albums/u273/foxymk1/4c562e71-99b8-4381-9a3b-a4fd488a04b4_zps153d729c.jpg)
![foxymk1 in the usergroup ‘Paid Member’ foxymk1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![foxymk1 in the usergroup ‘Local hero’ foxymk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
foxy
im good, car is getting there slowly
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Integrated engineering rods ( all balanced )
race bearings
modified cams
apr hpfp fuel pump
arp head and main bolts
and various other bits I found while on my build journey. I will be documenting as i go along just in case anyone wants to build a tfsi in their car.
Next on the list a hydrulic clutch conversion for the mk1 and get the car off to the body shop. I will try and update you and add some pics like I mentioned.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/3Avatar.jpg)
![butleraw in the usergroup ‘Paid Member’ butleraw in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![butleraw in the usergroup ‘Local’ butleraw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Raps3 in the usergroup ‘Regular’ Raps3 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I'm starting my mk1 project this year and still trying to make my mind up on which engine to go for.
At the minute I have a clean painted shell - just need to make my mind up on which way it's going then get cracked on with it.
Any info you can share on what's required, or share your research to date on putting this in the mk1 would be appreciated.
Thanks on advance.
![baller in the usergroup ‘Old timer’ baller in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi893.photobucket.com%2Falbums%2Fac135%2Fageyball%2FMy%2520Mk1%2520Golf%2Fmymk1003-1.jpg)
Tfsi engine ( golf, seat or audi )
Qty Description VW Part #
1 Engine control unit Various
1 Engine wiring harness 06F 972 619 [ ] (Not AJ or AS)
1 Alternator harness Various - with engine
1 Battery positive wiring IK0 971 228L
1 Engine Electrics Box 1K0 937 124K
1 Cover for Electrics Box 1K0 937 132F
1 Mounting for Electrics Box 1K0 907 361B
1 Cable Holder for Electrics Box 1K0 971 848E
1 Type 458 Relay (Normally found in engine electrics box) 1K0 906 381
1 Type 100 Relay (Normally found in engine electrics box) 7M0 951 253 A
1 Type 433 Relay (Normally found in interior fusebox) 3D0 951 253 A
1 Type 167 Relay (Normally found in engine electrics box) 191 906 383 C
5 5 Amp fuse
7 10 Amp fuse
2 15 Amp fuse
1 20 Amp fuse
1 Accelerator Pedal 1K2721503M (Black) 1K2721503L (Silver GTi)
1 Pedal Floor Bracket 1K1 721 187C
1 Pedal Bolt Hole Plug 1K1 721 989
1 Brake Pedal switch 1K2 945 511
1 CAN Gateway Unit 1K0 907 530.
![](https://i889.photobucket.com/albums/ac94/twain16v/th_tfsi.jpg)
