16v kr and 16v pl diference?
(In Topic #130387)
![Idealus in the usergroup ‘Regular’ Idealus in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1089718/krengine.jpg)
And my friends PL engine have not. What is it ? which is better ?
Thank you
![vdubber2 in the usergroup ‘Paid Member’ vdubber2 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![vdubber2 in the usergroup ‘Local’ vdubber2 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://img521.imageshack.us/img521/9396/kitt2.jpg)
![DarkViolet in the usergroup ‘Regular’ DarkViolet in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The main diference is that PL is catalitic, and have more smoother cams.
![possle in the usergroup ‘Old timer’ possle in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
suppose you could not use a cat. kr cams on the pl and see how it goes.
both should have wur
Saab 93 diesel daily
Run's fine. It's basicly the same engine.possle said
think the use 9a cams which are "smoother" on the inlet as to not damage the cat.
I think the inlet manifold in the PL is 42mm and in the KR is 50mm, but i'm not shore. :wink:
swap a kr inlet cam into a pl, and you have a kr engine
inlet nothing to do with it, kr got both the 42 and 50mm inlet depending on the age of the car
