Cold start and injectors issue!
(In Topic #129508)
![wiltz in the usergroup ‘Regular’ wiltz in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I have some problems with my 1,8 CIS engine JH. Problem is with cold start. It starts every time put it will not stay running even if i rev it want to die. I must play lot with rev and after that it will stay running and run very smoothly. I find in the forum that there should be black wire connected to starter. I have only red and black connected. Do anyone know where that black wire should go? How I can check is the TTS (thermo time switch working) ?
There is other issue also. I wanted to change injection seals but I could not get them out. Is there eny tips how to get them out? (Afraid to brake something)
Ville
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/102_0022_renamed_15080.jpg)
![bazmk1 in the usergroup ‘Old timer’ bazmk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
the Csv would not cause the problems you describe , it could be leaking injectors , flooding the engine bores & causing the problems described.
My csv was faulty for months & the car just took a few more turns to start then ran fine once started
baz
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi55.tinypic.com%2Flczmu.jpg)
![blackcherry in the usergroup ‘Local’ blackcherry in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mine were leaking and i ended up with petrol in my oil,i changed the injectors and flushed the oil out with engine flush added good oil and runs fine now.
i did have a bit of a battle with one or two of them,i think new injectors from gsf are around 40 each.
![peeriehutchie in the usergroup ‘Old timer’ peeriehutchie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://i627.photobucket.com/albums/tt355/vwhutchie/bonnetdoorcards046-1.jpg)
mine were solid as well
very quickly made this tool & it made the job a lot easier
![](https://i702.photobucket.com/albums/ww29/bazmk1/injector/090220101215.jpg)
![](https://i702.photobucket.com/albums/ww29/bazmk1/injector/090220101214.jpg)
![Dubster82 in the usergroup ‘Regular’ Dubster82 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The large tube piece was reduced in length to make removal of the injector underneath the throttle cable bracket, possible. Total cost £1.90 from local nut and bolt merchant, for the tube piece I used a leftover from a bicycle A-Head convertor but go to plumbers merchant and get some tubing that will accommodate the "stud connector" which is the widest moving part to be pulled up into the tube. Obviously old style injectors with coarse thread. Hope this is useful.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1082545/IMAG0074.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1082545/IMAG0075.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1082545/IMAG0076.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1082545/IMAG0077.jpg)
just make sure its definitely for the idle control relay, as there are lots of other relays that could be clipped above the fusebox. electric windows, coolant level warning light control, rear wiper, etc. tell us what the wire colours are
![willsmorke in the usergroup ‘Newbie’ willsmorke in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
