Refurbing my Cabrio Badges
(In Topic #129355)
![jq_quint in the usergroup ‘Local’ jq_quint in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
What do you think folks…
First stage was to take the badges off, after a little umming and arring I realised that would be a pain in the a**e so I set about masking off around the badge to allow refurb in situ…Luckily the backing sticky pads allowed the masking tape to run well under the badge…
First pics just show badge untouched but taped up and ready (note cabriolet badge to be tackled separate..
Pic1
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0285.jpg)
Pic2
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0286.jpg)
Then I rubbed each badge down with scotch brite and a fine file to pick out all the old polish that had collected over the years….Once done disted badge down with a clean paint brush. Finally wiped over with some panel wipe.
Then a couple of coats of matt black (pics 3&4)
Pic 3
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0288.jpg)
Pic 4
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0289.jpg)
With the matt black dryed off, I set about sticking on the transfers, used a strip of masking tape to stick them all together then apply each one at a time to the badge. Pics 5 & 6 show first badge set applied and second set waiting.
Pic 5
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0290.jpg)
Pic 6
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0291.jpg)
Once stickers were down well I put on two/three coats of lacquer to seal and gloss..
Once I took the masking tape off the cabriolet badge you could see the difference….and only took about 1hr all in…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0292.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0293.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0294.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0295.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080589/Photo0296.jpg)
Just got to finish the cabriolet and karmann badges….
\'91 Clipper : My first Golf…. \"..
![freeman in the usergroup ‘Local’ freeman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
GOOD JOB!
![Avatar](https://i872.photobucket.com/albums/ab282/Coventry50/smallavatar_zps9b03929d.jpg)
![Ginner in the usergroup ‘Regional Hosts’ Ginner in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Ginner in the usergroup ‘Old timer’ Ginner in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Ginner said
where did you get the kit from and how much, cheers Dave.
Thanks for the comments Ginner….got them from chortle on here….if you do a search you'll find him…
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/matrix.jpg)
COTM Team
![aircooled1968 in the usergroup ‘Local hero’ aircooled1968 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
great result they look really good
1.8T CABBY
1.8T CABBY
![ANDYCOOPS in the usergroup ‘Local’ ANDYCOOPS in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![TopperHarley in the usergroup ‘Newbie’ TopperHarley in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I need a Kit also for my cabby!!!
Where I can find it?…
I need For the following Badges:
KARMAN x 2pcs
VOLKSWAGEN
CABRIOLET
If someone can help me…I'll really appreciates it!
Cheers to all from Italy!
TopperHarley said
Yeah!
KARMAN x 2pcs
VOLKSWAGEN
CABRIOLET
PM Chortle on here, that's who I used….
I have full set of badges, with refurb kit apllied but peeled away a little in some area's could do with being done again if perfectionist
see pics here
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=93784&highlight=
1.8T CABBY
1.8T CABBY
if its just the kit see Chortle, top quality kit, great service :-)
1.8T CABBY
1.8T CABBY
I only need the refurb kit…cause I got a lot of badges at home(about 4 complete badge set!!!)…I've saw some pics about the refurb kit from chortle and it seems a very good solution…!
I tried to contact chortle but without any answer…I'll wait for his answer..!
have been away to Cuba, so literally just back.
So I have replied to all the messages.
The kits need to be put on really clean surface free from sillicones, waxes, dirt etc.
You can do these off the Car too.
Clean Clean Clean, spray a light coat of matt black paint, apply the foils and press flat from centre outwards.
Due to the variance of badges you may need just to rock the edge of a stanlry knife blade to remove any excess although these tend to be reasonably accurate.
Finish with some Satin finish laquer to seal them in and when you wash the area, you just need to be careful when washing and wiping around them, just wipe gentley from the centre to the edges.
Has anyone seen deks new car pics yet?
![dek in the usergroup ‘Old timer’ dek in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i'am a mk1 golf nutter RHODEISAN RIDGEBACK mk1 cabbys rule and you drool
Cant wait to do mine in the new year.
![Miotog in the usergroup ‘Paid Member’ Miotog in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Miotog in the usergroup ‘Local’ Miotog in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Think you could go into a life long business here with these badge kits!!!
Please can you send me details of where I can send payment and details for a badge kit set.
Many thanks
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/111image.jpg)
![Stu10002000 in the usergroup ‘Local’ Stu10002000 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
thanks
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-prn1/573216_600875947_1592336587_q.jpg)
![Austin Line in the usergroup ‘Local’ Austin Line in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
chortle
