Fuel pump not priming??
(In Topic #128550)
![Avatar](https://i1122.photobucket.com/albums/l537/marksw1/whitemk1golf-2.jpg)
![marksw in the usergroup ‘Paid Member’ marksw in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![marksw in the usergroup ‘Regular’ marksw in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I have been told that when you turn the key just before starting the car you should hear the fuel pump prime the system.
Anyone know why i my fuel pump does not prime??
![Nighthawk in the usergroup ‘Local’ Nighthawk in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
second does it run properly once it has started or do you have problems while it is running
______________________________
Golf mk1 1.8 gti cab (Still Working on it)
Merc E220
Merc E220
![25th Sept 2010 (6).jpg 25th Sept 2010 (6).jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1516546665/uploads/attachments/5a64aa67729b4.jpg)
Merc E220
Merc E220
if this is faulty may not be your pump at all
Merc E220
Merc E220
![bytor in the usergroup ‘Local’ bytor in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
It will be either your Cold Start Valve of Warm Up Regulator. Do searches on here - loads of info.
I would say from your symptoms it's the WUR - but you do the seacrh and then do the checks.
Merc E220
Merc E220
Good luck
Website Manager
vid clip of my mk1 staring from cold ( its being sitting a couple of days ) starts on the button & you can here the pump prime , no throttle
baz
100 3248 - YouTube
But when i bought the car the pump didnt prime & the Cold-start-valve was also faulty , but the car still started no bother after about 4 turns.
How many turns of the starter are we talking roughly ?
Website Manager
If the WUR is not allowing the metering head pin drop smoothly to the correct enrichment point for starting then it will take several turns to get it going.
cracyquiff sells relays , thats were i got mine & it primes , But your still not letting us know much turning over the motor takes to start when cold ?
baz
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/11image.jpg)
![lagger in the usergroup ‘Old timer’ lagger in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
99.9% its a dodgy relay
The cabs do have a lifter pump in the tank but the main fuel pump still needs to prime
You say pumping the pedal gets it started which shows the pump is ok otherwise the engine would not run as the fuel pressure is really crucial on these engines
use the search on here for fuse/relay box and youll find an excellent description of all relays
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
Fuze box wiring layout . Relay locations . Fuze locations
![Avatar](https://i572.photobucket.com/albums/ss163/79-85/players-2010-063.jpg)
![79-85 in the usergroup ‘Local’ 79-85 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
the only reason i knew that it should prime is a friend of mine's golf does it. and starts on the button.
i'll let you know if i solve the problem today..
