Suspension ??
(In Topic #128370)
![Avatar](https://i844.photobucket.com/albums/ab3/eddie110378/IMG00036.jpg)
![eddie32 in the usergroup ‘Local’ eddie32 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Suspension ??
My front suspension is original i think, as in it has the normal shocks and sprigs on it, now I cant afford coil overs but can afford a new set of the same ones.
Would this be ok ??, as in does anyone think i would be wasting money or would it be a good thing to do ??
I need to change it because it bangs like hell when i have no other option to go over a pot whole, or cant make out a sleeping policeman at night.
I can get the shocks for £40 and the springs for £15 so i think it would make the car better surely ??
Regards
1990 Mk1 Clipper Cabriolet
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://farm8.staticflickr.com/7126/6880073900_1bc77e86d9_o.jpg)
![PNERivage in the usergroup ‘Old timer’ PNERivage in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Will be interesting to see what the guys in the know on here suggest
As for your Rivage its lush !!, think when my roof fails I may get a Blue colored one instead of the black, and im ordering some chrome side strips as the aerial looks all alone now, (im sure I heard it whimper)
Iv just polished my wheels again, my other half is getting worried now !! LOL Any way just got my drivers side door to do now, the outer skin has come away at the bottom, so ill be drilling and riveting this week and using some body filler so ill be a busy boy, plus iv got the gloss work in the house to do (MARE) !
Regards all
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![djheap22 in the usergroup ‘Old timer’ djheap22 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If your putting the time in to change these then I would also order new dampers and boots.
If fitting coilovers you are going to be changing the top mounts I presume and dont forget they are naturally much harsher than the standard setup and will wear out a new set of top mounts quicker. So just make sure that harsher ride is what you are after, coilovers are for a lower racier and hence harsher ride. A good condition standard setup will give a much smoother ride.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1073125/PA070003.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1073125/PA270260.jpg)
1988 1.8 carb Golf Clipper
I was thinking of doing my top mounts first to see the difference
I have been looking at these on ebay
£24 +£9 delivery
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200501848518&ssPageName=STRK:MEWAX:IT
and these
£33 +£9
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150503158842&ssPageName=STRK:MEWAX:IT
What do you think?
tony
But the bottom set looks like it may be missing the small metal collar (Top Mount Spacer Sleeve).
try the following site works out at just under 40 posted for the set including the collar…pays you money takes your choice.
ive used the site a few years back with no problems.
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
Do you reckon this is my shopping list for a 1991 rivage cabby?
*07359 Strut Top Mount (In Stock) £22.04
*08431 Mount Spacer Sleeve (In Stock) £1.00
07299 Bumpstop, Front (In Stock) £2.90
02329 Boot, Front (In Stock) £1.70
Sub-Total: £27.64
(Delivery to UK : 2.75 Kg): £4.95
VAT @ 17.5%: £5.70
Total: £3
8.29
Eddie, I will have this sorted and fitted asap and let you know the results
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
How do you go about changing these is it a night mare as in do i need any specialized tools, never worked with suspension before !!
Any help would be great, or may be you could do yours and post a how to on here ??
Regards
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
Saves me the hassle then
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
That looks right to me for a cabbie, what I ordered as well, same part nos. The bumpstop, spacer and boot actually less than I paid in 2007
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
If your going through the hassle of getting this lot fitted I would also consider putting new damper inserts in as well, then pretty much new front suspension. I purchased item 100758 which was a fine.
But I notice VW spares aint saying if they have dampers in stock or giving a price, shame.
That is my car in the post, early guided me through the process and was a great help.
Very descriptive !!, Think it will work a treat
Oh think you have same wheels as mine ?? 14" Le Castelettes ?? think thats what there called,
Oh was going to say the underneath of my car is sound, covered in lots of WAX OIL, however those little wish bone suspension struts are full of surfice rust so you think they would be worth changeing, i would have to get a kit and there only £40 on ebay !!
What do you think ??
Regards
2005 Megane 1.6 VVT
2005 Megane 1.6 VVT
Regards
yeap wheels are "le castellet" came in both 14" and 15" and a few colour combinations. Myn are 14" which is the more common size. Site below can be a good reference source.
http://www.mk1vw.info/modules.php?name=Info&op=viewtut&page=2&id=76
post a few pics of the bits you think are crusty and I am sure someone will advise.
djheap22 said
That looks right to me for a cabbie, what I ordered as well, same part nos. The bumpstop, spacer and boot actually less than I paid in 2007only thing that gone up is the top mount itself. Now thats a surprize
Yes think i will do that. euro carparts have them £78 a pair delivered..
cant seam to see any springs thou, do they not do them anymore
soz not sure on springs, I reused them as car had low millage and looked in good nick.
hopefully someone can advise re springs.
