Taz"s mk1 cab
(In Topic #127913)
![drego786 in the usergroup ‘Regular’ drego786 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Taz"s mk1 cab
this is what i have done
new hood black cloth
new fuel tank
new filler neck
mk2 16v 19mm balljoints
mk2 16v/G60 front hubs gilrling 56 calipers carriers and new bearings
mk2 16v supper sport coilovers and top mounts
mk2 16v rear disk conversion including stub axle spacers
16v fly wheel
new clutch
new braided brake lines/pipes
16v servo/master cylinder
strenghened/reinforced steering rack mounts
polybushed engine mounts
polybushed steering rack/new track arms
polybushed rear axle
new timming belt
full engine bay refreshi.e all rubber gaskets changed
polybushed front wishbones
rose jointed track rod ends
G60 steelies 195/45/15
flared arches back
Mars red
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069534/16022010097.jpg)
pics
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/23012010044.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/23012010045.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/23012010053.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/23012010049.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/23012010050.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/12022010078.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/12022010079.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/30012010057-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/30012010058-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/15022010095.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/12022010081.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/12022010082.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/13022010087.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1069548/13022010084.jpg)
![GTInCyprus in the usergroup ‘Local’ GTInCyprus in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/matrix.jpg)
COTM Team
![aircooled1968 in the usergroup ‘Local hero’ aircooled1968 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
mmmmmmm
i would suggest that you make sure you know what you are getting involved with lol
no not really you just have to have the guts to go threw with it
first you have to cut the arches off including the inner arch
then you have to cut and shape the new arch repair panel so that it bubbles out the way you want it
weld the inner arch to the outer skin then weld the formmed repair panel to the car
a bit of filler and shapping not including the paint work
But and its a very big but you have to make sure that your wheels will not catch in the new archs ,,,,, the reason i say this is because mine is running mk2 16v/G60 hubs on the front with coilovers on the front and spaced out with stub axle spacers on the rear lowered on Koni adjustable shoks on the rear …… so when it was all fitted up it looked fine but when you had people in the car and went over bumps it would catch and grind on the wheels/archs to remedy this i had to raise the car 20 mm and now its brilliant
