Rear window removal
(In Topic #127265)
![Darkangelaudio in the usergroup ‘Local’ Darkangelaudio in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Rear window removal
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
How do you go about removing the rear windows (side and rear hatch) without breaking the windows or cutting the rubbers?
Can this be done? I really wanted to primer the car then use it whilst i get ready for the final stages…
Don't really want to buy new rubbers as mine are pretty good.
can anyone help?
Much appreciated!
White '82 Tintop 1800 Golf GTI
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I will post how it goes on, i might be asking for new glass!!!
Thanks again Chortle, i owe you a beer…
Putting them back in should be a bit easier.
Nylon twine and liquid sillicone.
Wrap the twine around the seal with the glass in place.
Crossing the 2 ends in the middle of the bottom seal.
Lower the bottom part of the seal into the frame, with the edges either side of the metal frame.
Have someone push on the glass as you uncross the twine and pull the twine out, it should fold the seal around the opening edges.
Eventually the twine should come out and your glass and seals should be in place.
That's 2 beers Lol only kiding….
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
![Aze23 in the usergroup ‘Newbie’ Aze23 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
chortle said
This link no longer works. I'm in the same position of needing to remove the tail window and disconnecting the heated element of the window
Thank you
