16v K Jet issue
(In Topic #126563)
16v K Jet issue
Got a lend of another MH to test with but its not giving any fuel through the new injectors on lifting the metering head flap but they are weeping with the flap down and even continues for a minute or 2 after the fuel pump is switched off!!!
When i put the old injectors back on i just get a contstant weak spray from the 4 of them as soon as the fuel pump is on which doesnt change regardless of lifting the flap. Again this continues after the pump is switched off. I even tried adjusting the idle screw but made no difference.
I'm now suspecting a system or control pressure issue. Has anybody got any experience of this?
If so, are they performed as normal otherwise?
so everything else as normal then? Just bridge the fuel pump relay and proceed as documented in the Haynes?
Google Sites: Sign-in
some more useful info:
