Engine Detailing
![fthaimike in the usergroup ‘Local’ fthaimike in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![SimonEire in the usergroup ‘Regular’ SimonEire in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
brilliant
![mike_B in the usergroup ‘Local’ mike_B in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
only just caught this thread. Engine looks better than it came out the factory.
OEM++
Amazing attention to detail, fit and finish
look forward to more updates
![stix123 in the usergroup ‘Local’ stix123 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Great work, cant wait to see it finished.
Steve
![chink in the usergroup ‘Local’ chink in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![herbiematt in the usergroup ‘Regular’ herbiematt in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![chrissy in the usergroup ‘Old timer’ chrissy in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Steve: I don't work in the car industry i'm in the health service sadly, tinkering around makes a change from my day to day work though. I have a friend who has his own body shop so borrowed his air fed mask for spraying, you have to 2k paint is lethal.
Carbs4ever: It was after reading your thead back in January this year that got me started on mine! Great job!
More updates this weekend………..
![Avatar](https://i416.photobucket.com/albums/pp246/slavic125/ebay012-1-1.jpg)
![slavic in the usergroup ‘Local’ slavic in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046434/Picture181.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046434/Picture187.jpg)
Golf Mk1 project
BMW 325i Touring
BMW 325i Touring
Fitted the braking mechanism
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046806/DSC_1852.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046806/DSC_1864.jpg)
Steering rack in with new original bellows. Rack has been sprayed in under hood black and U-clamps cleaned and freshly zinc plated.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046806/DSC_1869.jpg)
Part of the gear change linkage fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1046806/DSC_1877.jpg)
The rest of the weekend was spent fitting the wiring loom to the fuse box and running the wires in the engine bay.
Golf Mk1 project
BMW 325i Touring
BMW 325i Touring
![peeriehutchie in the usergroup ‘Old timer’ peeriehutchie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://i627.photobucket.com/albums/tt355/vwhutchie/bonnetdoorcards046-1.jpg)
Fitted wiper mechanism
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1899.jpg)
Wiring loom in.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1911.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1913.jpg)
Professionally rebuilt gear box sprayed in Aluma Blast and newly zinc plated parts put back on. New engine mount rubber pressed in.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1953.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1931.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1928.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1925.jpg)
Front suspension and wheels put back on
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1940.jpg)
Engine taken off stand using engine hoist and lowered to fit pressure plate, clutch disc and flywheel
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1961.jpg)
Transmission fitted on to the end of the engine and bolted into place
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1968.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1966.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1962.jpg)
Engine lifted and positioned in engine bay.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1971.jpg)
Engine carefully lowered into position and fixed to engine mounts
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1973.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053263/DSC_1972.jpg)
![Avatar](https://t0.gstatic.com/images?q=tbn:K1BwZWPcVltvsM:http://atpowershop.co.uk/catalog/images/products/direct-to-head-throttle-body/F7R%2520Williams%2520-%25201.jpg)
![oz_79GTi in the usergroup ‘Regular’ oz_79GTi in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/102_0022_renamed_15080.jpg)
![bazmk1 in the usergroup ‘Old timer’ bazmk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Stunning work
Im thinking about pulling my engine out this winter to clean my bay etc , Some people prefere to drop the engine+box which was the method i was thinking about doing , but going from the top with the whole unit didnt look to bad from the picts any extra tips?
baz
Baz. Putting the engine back in was not as bad as I thought. It took two of us one at the gearbox end and one at the opposite end. You really have to tilt the engine down (gearbox end) then just line up the engine mounts to the brackets. Just take your time!
Mike. Will PM you some photos of the order of bits on the wiper shaft.
New original rad fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1976.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1984.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1992.jpg)
A little tip for fitting the snap ring back into the retainer on the starter motor
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1999.jpg)
Oil cooler hoses fitted. These are the original one cleaned and zinc plated.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_2007.jpg)
Just a few photos of how the bay is looking at the moment. I think another week or two it will be complete!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1980.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_1983.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1053498/DSC_2022.jpg)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi40.tinypic.com%2F245lnno.jpg)
![Swallowtail_uk in the usergroup ‘Paid Member’ Swallowtail_uk in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Swallowtail_uk in the usergroup ‘Old timer’ Swallowtail_uk in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![birkin in the usergroup ‘Local’ birkin in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
