16v conversion wiring using both fuse boxs???
(In Topic #124378)
http://www.a2resource.com/electrical/electrical.html
…no-one can really help you without being able to tell how you've wired it up so far.
http://www.clubgti.com/forum/showthread.php?t=215372
as above though, there are like 3 wires to the fusebox to run the kr. the spark controller is completely wired in the engine bay, no fusebox feeds at all. ecu has a wire to trigger the fuel pump, but you could just use a k-jet fuel relay without a rev counter in.
isv controller, throttle switch and over-run cutoff valve need an ign live feed and you need fuel pump power for wur and starter motor feed for 5th inj thermoswitch.
really is an absolute doddle to wire in. if car was originally a k-jet its even easier 90% of the wires you need are there already.
fuel pump power pin is M/2
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
\- red/black - spade is for the isv control unit, the main wire is the rev counter feed
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
\- black/yellow - idle switch feed (12v feed with throttle shut)
rubjonny said
need pretty much all the wires there, only one that isnt required is the black/yel on plug 9. the red/yel may also not be required depending how you plan to run the fuel pump
had'nt thought about it,i'm gonna run an R1 fuel pump,whats the best way to wire it in
alternatively wire up a std trigger relay for the pump, but run the earth pin from it to the red/yel wire and it'll be ecu controlled.
:pray: cheers for that,this way sounds good to me,not too gud with electrics,dont suppose u have some sort of diagram :redfaced:
