cabriolet roof leak
(In Topic #122847)
cabriolet roof leak
or this is the link on how to fix the leaky handles
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=63414
hth
The vynil does that after some time, there is also a small area that you need to apply sillicone too. It's the first screw hole you come to when you remove the first side seals. You need to remove the seals and the metal holders first and then replace the foam gaskets,
then the metal holders, then apply a good dollop of sillicone around the srew hole and screw. Then fix down. Then slide the rubber seals back in.
Another tip is be carefull as the metal holders have plastic clips in the ends that the seals go up too, these snap off if your not aware.
i went for the large one
KERB$IDE KU$TOMS team no work
VWT5WOB said
i was told buy my trimmer to use this . i have done the mohair roof now 2 coats but not been out in the rain yet Web Page Name
still no good if the foam gasket seals are gone. Make sure there is some sillicone sealant around the front screw holes under the rubber seal it's self
