new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
mickeyone said
did u buy them injectors of me dude! sure your the guy from south yorkshire!
yep i did and yes from s,yorks
thought id knock a short runner up to find ive not enoegh room at the front
so that was thown in the scrap
next only thing i could do is modify the stock intake manifold but keep the runner lengths the same
ill just finish the welding 2moz  and do of wireing  unit turbo arrives
managed to weld rest of the intake  and modify the rocker cover too
modifyed the breather  and has a better idea with wire gauze and oil splash plate , which should help in boost , what a pain to alloy as the alloy contains very small fragments of hot oil  and i assume over the years its contamiated the alloy , but got there in the end
fits a treat nice and air tight [:P]
also saved a good 5inch  , so means i dont really have to change the sump , but i think ill make a shorter one
hi guys well had a bit of free time so thought id make a new coil pack mount
removed the old sensor and filled the old hole up with alloy
lump of 3mm alloy then driled a few holes
then added a 5mm lump of rubber and bolted the coilpack up to the back plate
noticed i left a gape between the timing chain cover and the back plate , save engine heat on the coil pack and added the rubber to keep it cooler ,
injectors re wired, and all engine loom wires alterd , tempord to try a start up 2moz ,,be a tad noisey but should fire up
first off thought id check the intercooler pipe fits a dam treat with clearance too , think ill tig a dump valve in there, also heated the plastic vacum pipes for the brake servo  and re solderd all the wires and shorternd them,
next as i have a bit more room i pulled the exhust side in around 2inch ,(saves a rattle
then new turbo arrived so thought might as well make a manifold , first tempory fit ,
you,ll notice its on a angle reason is ive no room to run a dam boost pipe , ive an idea thow lol
few start pics of the turbo and manifold progress
didnt like it above so alterd it lol
lolo i hope u are ok and that,
loving the car mate
yearh fine cheers
beer bad 2day so no real updates couple of pics of the manifold i had to make , just needs welding finishing off and external wastegat modifying  , then ill get the buggar bolted up
You have some awsome skills there mate, loving the work.
ok i supose fills a hole lol
glad youre ok mate! everyones been wondering if you were ok!
not too mutch but had a slight engine prob ( nothing bad ,just a stuck hydrolic tappit ) now runing on 6 pots , dosent sound too bad tbh , also added oil t piece and reducer, and made oil return 19mm bore , modifyed ht leads to suilt, redone manifold had a small blowing, had to alter external wastegate still in the way but ill mod the air intake, next is modify some boost pipes , sensors, intercooler,hoses,, ive also dropped on a pair of poly bushes which ill make some new mounts from too few pics here
quick engine video
View My Video
well few more little updates as the sun was suning today ;)
first had to chop the intercooler and weld 2 cores together and modify with pipe work , as the single wasnt cooling enoegh
then welded the lot together
somert like this
then nearly forgot needed a blow off valve fitting so welded that on too lol
you can just see it here
next hit a slight problem with the outlet on the boost pipe so thought chuff it ill make a s bend as to flow few engine shots at mo
mate this is awesome work as per usual, that intercoolers a beast  :twisted:
keep us updated would love to see this on the road
all runing fine only at 8psi but feels ok,intercooler works a dam treat showing 8deg on intake temps and nearly 50deg on the outlet not bad to say theres no airfilter
As always excellent work!
Love the custom intake, vr bit!
Keep up the good work!
Pete.
Pete.
cheers pete
engines runing very well at 15psi at mo , oil temps, oil pressure, afr, timing, fueling map best its been so far ,, so thought id treat the caddy to another homemade header tank , made from alloy , as ebay prices are a dam rip off
think ill make a quick water bottle 2moz too ,, fills a hole lol
also made a quick water bottle too ,
got a bit carryed away after making a header :laughing:
not mutch to add so made another for the brake fluid , im in two minds wheather i like it thow ,
then decided to skim some alloy down and make a start on the new engine mounts,
had a thought today ,(yes another lol) about a post eailer in the therd , about wheel banding , so i tryed one , prob is i really need 17inch 7.5j rims hard to find , so i tryed one on 6.5j rims 15inch heres how it looks
standard ones fit sound as stock on the front heres a quick pic and no rim cutting needed
evern made a jig to re line the rims ,, unsure what to do , asi like how they fit on the fronts, as the tyes wount catch the archers when i slam it
