cold start valve question
(In Topic #121913)
![batman04 in the usergroup ‘Regular’ batman04 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
also i tested the cold start valve by running a bypass on the pump to run it without turning it over everytime, and putting a direct feed of power to and earth it and it worked good. so i can't understand why it wont work cranking over. i know it gets it opower from the starter motor. does the cold start valve run through a fuse or relay? cheers
batman
![Avatar](https://i275.photobucket.com/albums/jj301/1990gticab/golfattescos-1.jpg)
![jaycab in the usergroup ‘Paid Member’ jaycab in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jaycab in the usergroup ‘Old timer’ jaycab in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Slowstarter in the usergroup ‘Local’ Slowstarter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![machine in the usergroup ‘Old timer’ machine in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
machine said
I've had a problemwith my cold start valvefor a while in the there's no voltage to it. Can I run a lead from the starter motor to the the valve to test it then?
Look at the wiring diagram - the TTS and cold start valve are both in the circuit, which is fed from terminal 50 either from the starter motor or the fusebox (+12V only when starter motor cranking). Its not just a case of running a wire here & there, you'd need to make up the correct circuit to test it, or wire a dash mounted switch independent of the TTS.
![s3wil in the usergroup ‘Newbie’ s3wil in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Considering the Starter is cranking drawing alot of power from the battery I would say it is very unlikely to have 12V as anyone with A voltage VDO guage would see it dip down to around 9V on cranking as I do.
