Corrado Seats
(In Topic #120885)
![Ceza in the usergroup ‘Regular’ Ceza in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Corrado Seats
T
![Rupe76 in the usergroup ‘Local’ Rupe76 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Are there any other straight swap seats you can think of, MKII Golf ones for example?
rear seat is another matter tho, pretty much only seat that will fit is cabby as its narrow and has the big strengthening bar under it
rubjonny said
yeah and mk2 golf. since clipper is newer than 84 it has MK2 Golf seat runners
Rado seats can be made to fit and MK2 rear bench fabric can be used to cover a MK1 Cabby bench as well. Seen them both done many times and they look good too!
T
The corrado rear bench takes significant modification to get it in, I know this becasue I had one to try in my cabby. becasue there is a massive strengthening bar at the base of the rear seats, the rado upright sits far too high. so you have to chop a fefty amount out of the bottom of it to get it to sit low enough, then retrim it.
well happy with tha, thought i was only having the front seats. gotta have a go at getting the back bench in as well, be rude not to!!
rubjonny said
yeah would look well good with the rear bench in, I had a look and just gave up on the idea as too much work, got mesen a nice late spec cab interior instead![]()
Exactly the same here.
Worth a try though so good luck.
T
