black gti project. update 20.5.10
(In Topic #119570)
Regards Volkswarren
Dib.
car
Re: car
g60go said
Doesnt look too bad!!! Is there must rust on it?
Am Putin front panel, 2 new wings n stills on it because sum one has not fitted them right n they don't line up, back panel due to rot and 2 doors coz sum little chavez kicked them in, the undernether is soild
the enigne is finaly out
its new home for the next year
Quick question, how hard was it to pull the engine and box? I need to remove mine soon and just wondered if you had anyd advice or tips to make it easier?
sjuggins said
Looking good fella, keep up the work.
it was not that bad my mate took it out for me but the exhaust bolts were sized soild so he found it easyer to take the inlet manifold off so he could get the exhaust manifold off, all in all it took n hour n a half 2 get it out, he did say his subaru 1 was easyer 2 get out tho :? lol
what's the plan for the car, standard or mods?
studs said
very good progess mate
Am gona go for standard probs just wit a couple of little changes
wire wheel ready to go
after 10 mins
half n hour later
couple of little holes which need migin up
bulk cut off the front panel
roof
Tools need to carry out the task ahead:-
drill,grinder,belt sander, wire wheel, spot weld drill bit, vise grips and most of all a welder.
1st bulk cut the front of the inner wing just infront of the first wing bolt hole make sure dont cut behind the hole as u need it to line the new panel up. bulk cutting it will make it easyer to juggle the new panel into place.
2nd wire wheel where the battery tray spot welds the inner wing so u can see the spot weld the drill them off.
3rd cut around the battery tray on the inner wing so its makes it easyer 2 fit the new panel when trail fitting.
4th juggle the new panel into place using the old front inner wing bolt hole put a wing bolt though the new inner wing bolt hole and into the old panel, then clamp the panel into place at the back of the new panel and at the bottom of it.
5th cut a nice neat staraight line though both panels about 5mm form the back edge of the new panel this is were u will be welding the new panel in.
Keep up the good work though. Good to see the mk1's being saved
92 caddy, Now stripped for full rebuild
83 golf gti R1 carbed 16v(soon to have 1.8T)
07 Leon FR TDI daily
Cambridgeshire regional host
