Removing injector seats? Inserts? what they called lol
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/WP_20150616_004.jpg)
![hazhammy in the usergroup ‘Regular’ hazhammy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Life Member
Am I right in think that the 12mm allen key goes down the centre of the seal to remove it? Does the whole dark bit come out and you unscrew the pink bit from it?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1015878/INSERTS.jpg)
Reason I'm asking is cause some of the 'collars' on mine have broken off while replacing the injectors and they were leaking. Currently seal with silicone as a make do repair.
Dan
![Slowstarter in the usergroup ‘Local’ Slowstarter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Life Member
is the part on the left a new part that screws onto a long piece? And the bit that has broken is the older version of the part on the left?
I'm picturing the parts insitu, would I use the allen key to run down inside the longer part on the right and it would unscrew from there? or does the allen key simply grip the plastic part?
Life Member
