Tappet Noise
(In Topic #120178)
![speedfin in the usergroup ‘Newbie’ speedfin in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Tappet Noise
Just bought a 1990 Clipper Cab with 1.8 carb engine with the engine code 'EX'
Not sure if it's got mech. or hydraulic tappets.
Evidently the EX engine ran from '86 to '92 but hyd. tpts. didn't come in till '88
Got it sorned at the moment while I sort out a few things - will tax it 1st Feb.
So it's been standing since I bought it last October - drove it home 150 miles without any probs and I don't remember a constant tappet noise then although the previous owner said it was a bit tappety till it warmed up.
Had it running in the garage today for about 15 mins till nice and warm and there was a very clear 'tappety' sound - came on straight away and stayed constant even when warm - it was there as well when reving the engine and when overrunning.
I imagine that I I take off the rocker cover it will be clear if it's mech. or hyd. tappets.
Any thoughts would be welcome.
Understand a lot of Golf engines can be a bit noisy.
Regs
John
![djheap22 in the usergroup ‘Old timer’ djheap22 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Ive always been told Hydraulic tappits for latter engines.
Myn produces a tappy sound when its cold, but goes once you get running sometimes lasts slightly longer ie cover a mile or so and its gone. Ive always put this down to age and its been fine for me for over 2years, not getting any worse.
You could start with the basics change oil and filter, I use Semi synth 10w40.
If you wanted could also use an engine flush, but I havent gone down that route as I dont want to run the risk of dislodging any gunk and it blocking one of the oilways. Not too sure if thats a valid concern, but as myn is working fine dont want to risk it.
1988 1.8 carb Golf Clipper
drop 1l of ATF into the oil, bog std auto box stuff. drain some of the old oil out if requires, dont want to overfill. drive it gently for a week or so, then drain out and refill with fresh oil and a new filter.
the atf has detergents in which can help unclog sticky tappets
Will be sloshing in a load of ATF tomorrow and will let you know how it goes.
Regs
John
I put in 3/4 Litre of ATF and the tappeting whent off after about ten minutes of mixed reving and tickover.
I'll give it a couple of runs then a good flush and a fill of decent semi-synth.
Many thanks again for your help.
Regs
John
might give this a go with myn, due an oil change soon.
I'll do a post in 2 weeks.
Cheers.
![Avatar](https://i259.photobucket.com/albums/hh319/brucie_boy/Photo157-1.jpg)
![brucieboy in the usergroup ‘Local hero’ brucieboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
is yours auto or manual?
if it works and you'd recommend it could you give me the name of it and how much it was and how you did it, unless its as easy as stated above, and in that case ignore that bit lol, thanks matey, its the only noise that the car makes that i dont like!
take care!
:mrgreen:
![](https://i259.photobucket.com/albums/hh319/brucie_boy/sig-2-1.jpg)
Rubjohnny i take it you have also tried this personally thus recommending not just on word of mouth?
I think some peeps will be concerned as wether it could cause the engine any issues fella if you can reassure us.
But i will give it a go with 1/2 litre and let you know how it goes as i have a slight tappy noise, not got any worse but if i can get rid, more the better.
Will do it this week and update once oil changed in approx a week
Pete :wink:
I got this tip originally came from the legend that is TSC on clubgti, I consider anything he says to be undisputed fact
I bought 1litre of comma ltf today.
i will be putting it in my block and will post outcome
Cheers fella
Pete :wink:
Is the noise suppose to go during the period the atf is in, or is the atf the cleaner, and the putting in of fresh oil stops the noise?
My block has solid lifter not hydro
Pete :wink:
this is for hydro tappets, it cleans out any crud inside them so they can pump up properly. it will do absolutely bugger all on solid lifters, if they're tapping you need to reshim
![millfischk69 in the usergroup ‘Paid Member’ millfischk69 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![millfischk69 in the usergroup ‘Old timer’ millfischk69 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
Basically any block before 86 will be solid lifter.
My mk2 is an 86 and that has Hydro
Tappets nice and quite now.
Kept the ATF in for about a week - just drove gently.
Drained and filled with flushing oil then ran in garage for about 20 mins reving from time to time then drained and filled with semi-synth and a new filter.
Tappets now go quite within a minute or so.
