Vacuum Advance
(In Topic #119046)
Vacuum Advance
One goes to the carb and one to the manifold is this better or worse than the standard one?
~Madferret
Mk1 1457cc 5door GX '83
Not a case of being "worse" as it does the job intended- to keep the timing as optimal as it can be, considering that its all purely mechanically done.
If its all working ok, then let it alone, you cant fix it if its not broken.
Overboost said
One is to provide advance, the other is to retard the timing during different throttle conditions.
Ok just wondering if it was a valid mod or just someones left over junk, thanks
~Madferret
~Madferret
