16v Conversion, timing marks
(In Topic #118920)
Im about to put the box back on the engine, im using a 1.6 box on a KR so ive got the 1.6 flywheel etc. Question is what timing marks will i then use for timing the 16v? do i have to make some new marks onto the flywheel?
Ste
1982 Mk1 GTI
Now with 16V
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=52163
Now with 16V
If its too late for that, you can instead get a timing light with an advance dial in, then use the TDC marker. Alternatively, measure the diameter of the fly and use some PI calculation to work out how many mm 6 degrees of advance works out at, measure from TDC and make your mark.
either way the ignition timing mark on these flywheels is in the wrong spot!
"rubjonny" said
fit a later MK1 1.8 210mm clutch kit, it'll all bolt up to the KR and your old gearbox just fine!
quote]
Wrong!!! The 210mm clutch does not fit the FD (1.6) Gearbox. Trust me I learnt this from experiance…… The clutch will just spin around on the splines on the box as the 1.8 box had a bigger input shaft spline diameter. You need a 200mm clutch, but you should realy utilise the KR flywheel mate thats the setup I have atm
What you fitted was a 16v KR clutch kit, which as you say has bigger splines
There are 2 size splines on 020 boxes, you have the std 1.5-1.8 8v size which has 24 splines, and the 1.8 16v/2.0 8v size which has 28 splines.
I know this from experience, as I also have a MK1 with a KR 16v engine and a FD box, running a 210mm clutch. Unless I'm mistaken and its not actually been driving me to work for the last 6 months
Did I? in that case then im mistaken! I must have forgotten… too much beerrubjonny said
1982 Mk1 GTI
Now with 16V
Now with 16V
