1981 mk1 golf c overhaul
![WeeTony in the usergroup ‘Old timer’ WeeTony in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
love that you just stripped your engine, the car's a shell, and in your big pile of new parts, you've got a head unit and gearknob!!!
that's ambition!
love it, you're putting me to shame.
![](https://i183.photobucket.com/albums/x252/WeeTony54/sig-1.jpg)
![Laura in the usergroup ‘Local’ Laura in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
plus its the little things that push me to finish it lol
dirty hub vs clean hub
![](https://vwgolfmk1.org.uk/uploads/pbextract/996420/IMG_4837.jpg)
black handle vs chav handle
![](https://vwgolfmk1.org.uk/uploads/pbextract/996420/IMG_4842.jpg)
and 1 primered bay!!
![](https://vwgolfmk1.org.uk/uploads/pbextract/996420/IMG_4856.jpg)
not quite so prtty on the other side
![](https://vwgolfmk1.org.uk/uploads/pbextract/996420/IMG_4853.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/996420/IMG_4859.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/999243/IMG_4902.jpg)
bay now
was told me covering it all in primer was a bad idea n t all needs to be metal lol
![](https://i11.photobucket.com/albums/a194/taylorthp/IMG_4905.jpg)
arty farty pic of chris aka golf gt welding his bay
oh n todays delivery
![](https://vwgolfmk1.org.uk/uploads/pbextract/999243/IMG_4923.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/999243/IMG_4925.jpg)
![studs in the usergroup ‘Paid Member’ studs in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![studs in the usergroup ‘Old timer’ studs in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
is the paint top, if so, Nice 8)
VW texas yellow
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20200305_113915.jpg)
![Diesel-dubber in the usergroup ‘Local hero’ Diesel-dubber in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![G60RGE in the usergroup ‘Old timer’ G60RGE in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
thanks
![Avatar](https://www.vwgolfmk1.org.uk/images/banners/volksdepot.jpg)
![smillsey in the usergroup ‘Paid Advertisers’ smillsey in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![smillsey in the usergroup ‘Local’ smillsey in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
too true, just not as quick as you, but i cannae wait to put my new valve caps on
mon the restos!
went up with a massive list to do tonight n eneded up doing nothing apart from mending the hole in my sill … lots of grinding back to do now but at least its solid woo
some back ground on "the hole"
looked like this when i got it
![](https://vwgolfmk1.org.uk/uploads/pbextract/1001318/golfc2.jpg)
on grinding it back i discovered it looked like this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1001318/SDC10375.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1001318/SDC10376.jpg)
which made this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1001318/SDC10377.jpg)
Welded a small plate in but the surrounding metal was like tin foil
started grinding it back last night and jusy started going through so thought sod it all do it properly
crappy iphone pics coming up
after grinding back
![](https://i11.photobucket.com/albums/a194/taylorthp/DF.jpg)
taken back to decent metal
![](https://i11.photobucket.com/albums/a194/taylorthp/untitled-1.jpg)
ouch thats a big hole
then 3 hours of messing with sheet metal, body work hammers and lots of swearing an d throwing tool about, id managed to fabricate a decent enough peice…
still required some tweeking but it was getting late
![](https://i11.photobucket.com/albums/a194/taylorthp/D.jpg)
im proud of that
![dibbler in the usergroup ‘Old timer’ dibbler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Dib
![](https://vwgolfmk1.org.uk/uploads/pbextract/1002543/SDC10597.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1002543/SDC10605.jpg)
me looking like i should be skiing not working lol
![](https://i11.photobucket.com/albums/a194/taylorthp/SDC10602.jpg)
Christophers new higher turrets!
![](https://i11.photobucket.com/albums/a194/taylorthp/SDC10606.jpg)
![](https://i11.photobucket.com/albums/a194/taylorthp/SDC10607.jpg)
and a guy that looks liek the guy off viva lol
![](https://i11.photobucket.com/albums/a194/taylorthp/SDC10571.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture996.jpg)
direct fit into the standard gti centre console
prepping for paint has now started
came in on moday and a door had magic'd its self onto the car… i was very impressed the car has started putting itself back together haha!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1011.jpg)
the old one was rotten at the botton and this one is better so christopher decided to fit it for me
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture.jpg)
after lots of sanding
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1000.jpg)
the door has for some reason been half sprayed in white … i was a little worried it was covering some rust of dodgey repair up but nope… all sanded back fine
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/SDC10640.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/SDC10638.jpg)
wow you can see how much dust there is… i finally invested in a face mask after coughing up god knows how much crap. cant be healthy
The other side
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1001.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1004.jpg)
This was the roof!
yummy… not been washed in years and by the looks of it never polished haha
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1007.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1008.jpg)
SAND SAND SAND
velvet looking roof
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/Picture1010.jpg)
and the workshop doodle pad
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/SDC10645.jpg)
couple more essential bay pics… almost 100% there now
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/SDC10642.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1004212/SDC10643.jpg)
bought a whole sill section insted of trying to fabricate a peice the right shape to weld in…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10746.jpg)
cut down to the right size
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10748.jpg)
winer! happy with that, means ill also get the right little lip in which although i didnt notice it at first would bug me now i have noticed it lol
bay almost ready for primer… finally
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10752.jpg)
new wings
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10754.jpg)
something a bit wrong with our inspiration wall
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10755.jpg)
and the result of todays work… ouch..
dont let go of an angle grinder when its on…
![](https://i11.photobucket.com/albums/a194/taylorthp/SDC10763.jpg)
start of the new dash pod design
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10742.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1009908/SDC10739.jpg)
![MUSCLECAR in the usergroup ‘Newbie’ MUSCLECAR in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
IHAVENOIDEA
IHAVENOIDEA
![](https://vwgolfmk1.org.uk/uploads/pbextract/1055990/IMG_6641.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1055990/IMG_6656.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1055990/SDC11194.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1055990/IMG_6635.jpg)
