starting problems with show winning golf
(In Topic #118693)
batman.
k-jet fuel
Once the leak is fixed, there's a pretty simple test you can do for the injectors. The test is to check good spray patterns, a good conical spray and no leaks upon stopping the intended injection. There are a few vids available online or you can view a pdf tutorial here:
http://www.vwgolfmk1.co.uk/Main/Testinjectors.pdf
If you are still having problems with fuel supply and you're not getting fuel to the injectors, maybe look at fuel pump, lifter pump or accumulator. A rusty filler neck and/or tank may be causing blockages. Check fuel filter for nasty gunk. There are some good troubleshooting guides on here, if you look under FAQ in the forum. I would have been a bit lost without this place.
Finding and stopping the leak has to be first port of call though.
